Old 02-20-2019, 09:43 AM
jgaz jgaz is offline
Default changing sample rate or clock source on MTRX popping monitors
Has anyone else experienced this? Even with the control room monitors cut and volume pulled down to -100%, my monitors are popping when I change the sample rate or clock source in DADman.
Thanks,
Jeff
Old 02-20-2019, 10:19 AM
creativecontrol's Avatar
Default Re: changing sample rate or clock source on MTRX popping monitors
Greetings,
What do you have your Adapt To set to for your particular clock choice?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-20-2019, 10:38 AM
Hi Jeff,
Small correction, it's when I change sample rate (when Adapt To is set to "internal") or when I change the Adapt To setting that it pops my monitors (say from internal to Dante or MADI).
Thanks,
Jeff
Originally Posted by creativecontrol View Post
Greetings,
best,
Jeff
Old 02-20-2019, 02:20 PM
BScout BScout is offline
Thanks,
Jeff
I do not have this issue, if that helps for comparison.
All digital will pop when changing sample rates but cutting the monitors doesn't pass the pop to to the speakers. Cut is a complete mute.
However, I'm curious what your monitors are. Are they hooked by digital/AES? In which case the sample rate change will effect them (because your monitors will be asynchronously re-clocking too.) That would be expected unless your monitors have a function to automute when reclocking.
Mine are connected via analogue, for reference.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire HD10 + Max11, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.5RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 02-20-2019, 04:27 PM
Good call, ours are being fed by a madi D->A and then analog from that device to the monitors. I'm used to digital converters muting their outputs when they lose clock. I'll see if there's a setting on them to get them to mute instead of pop.
Thanks!
-Jeff
Old 02-21-2019, 09:23 AM
Just in case anyone else runs into this issue, we have a DirectOut Technologies Andiamo MADI da/ad. Changing it to clock off of the wordclock input rather than MADI fixed the issue, no more popping of the monitors when switching sample rates!
Old 02-21-2019, 10:00 AM
Thanks for the update!
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-20-2019, 10:52 AM
Actually, further update, I only thought that fixed the issue but found out that it didn't. It wasn't until recently that I've had a chance to dig into this issue further and I've been both in contact with Avid and Directout Technologies.
In the end, I'm advising everyone I know to stay away from the DirectOut Technologies Andiamo Madi DA/AD. There's no workaround other than powering off monitor speakers before changing samplerate or simply replacing these units with another brand that won't pop their outputs when changing samplerate.
-Jeff
Old 03-20-2019, 12:57 PM
You haven't specified what speakers you are using, but other than the annoyance of the pop, those pops should do no damage to your speakers. You can check with the speaker manufacturer, but those re-clocking pops aren't DIRAC spikes or full scale signal and speakers can handle those easily without damage.
I honestly don't know a standalone DA converter that mutes when reclocking. The only ones that handle that easily tend to be ones that SRC any input (so they aren't actually reclocking but just resampling the digital signal on the way to the speakers.) I know a few makers who have that.
Old 04-16-2019, 07:32 AM
...I honestly don't know a standalone DA converter that mutes when reclocking....
Which doesn't mean it's not a good idea... ;-)
http://www.richbreen.com
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Problem detected with audio clock. Check your clock source and sample rate. teleguy2 Windows 6 06-26-2015 01:47 PM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 08:42 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
