Old 04-16-2020, 03:37 PM
Silverpool64 Silverpool64 is offline
Default VSTs in Pro Tools?
I have a VST plugin I would like to use in Pro Tools (the latest version), but I've found out Pro Tools doesn't support VSTs. Is there a way to still use VSTs in Pro Tools? I don't really know anything about Rewire, but I've heard it does cool stuff.
Old 04-28-2020, 02:33 PM
Panacci Panacci is offline
Default Re: VSTs in Pro Tools?
Blue Cat audio,s Patchwork.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 04-28-2020, 02:46 PM
JFreak's Avatar
JFreak JFreak is online now
Hi, welcome to the community.
First you should investigate if the plugin has AAX version, it will run much better natively. But if it does not have, as said, you need a wrapper to host your VST. Bear in mind AAX automation features are not going to work in the VST
Janne
Old 06-14-2020, 11:28 AM
MicMan MicMan is offline
I use BlueCat Patchwork whenever I need to host a VST or VST3. That said, I always use AAX if it's available.
Using VSTs in Pro Tools 9 smrpg99 Pro Tools 9 32 08-13-2012 07:12 AM
Adding vsts to my pro tools sessions(((((New issue))))) Fitzgrade Pro Tools M-Powered (Win) 2 04-02-2012 04:18 PM
Free Vsts Joemamma Pro Tools M-Powered (Win) 5 06-11-2006 04:32 PM
Have to shell out another $100 to use VSTs? joo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-24-2005 06:59 AM
Anyone tried PowerCore VSTs? AppleFunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-21-2004 06:43 AM
