Kernel Panic on Mac
I have a 2.4GHz Late 2008 Unibody MacBook running Snow Leopard and ever since I have installed ProTools 8 on the computer I have been getting kernel panics. Usually never when ProTools is actually open but after it closes and it does it at weird times like when I'm trying to shut down or quit safari. I'm pretty certain they are linked to ProTools because they only happen when ProTools has been opened. I downloaded the prerelease of 8.0.3 which is SL compatible hoping it would solve it but it didn't. I'm wondering how to solve this issue, should I wipe the drive and reinstall the OS or is there another way to alleviate this? I'd appreciate the help, thanks.
"I am the hope of the Universe. I am the answer to all living things who cry out for peace. I am protector of the innocent. I am the light in the darkness. I am truth... ally to good, nightmare to you!" -Goku, Dragon Ball Z |
Re: Kernel Panic on Mac
Freaky weird poop can often be traced back to bad ram. Between Snow Leopard and PT8 some of your ram may have shat itself?
It's always the last place anyone looks. Run Activity Monitor/CPU and see if you can spot anything. No one wants to replace that expensive stuff, and will look anywhere else for the problems first. Try reseating your ram or swapping it out maybe?
- Ando 003 / ADA8000 iMac 24 2.33ghz / 3gb Ram OS X 10.6.2 Pro Tools LE 8.01CS1 DVTK2 LOGIC 9.1.1 |
What interface are you using? If it's the Mbox 2, and you are plugging/unplugging it while your Macbook is still on, then that's the cause. It doesn't support hot plugging.
Work: Mac Pro 2.93 GHz Quad-Core Intel Xeon, OSX 10.6.8, 8 GB RAM, Digi 003, PT 10.3.9 +CPTK Home:2013 nMac Pro 3.5 GHz 6 Core Xeon E5, OSX 10.10, 16 GB RAM, UA Apollo Quad Thunderbolt, PT 11.3.1 |
Kernel Panic | Bray90820 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-29-2010 11:14 AM |
Mbox 2 Mini causes Kernel Panic after 8 months of no issues. Panic Report Included... | oneakmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-09-2010 08:52 AM |
Kernel Panic with 003 | DSwartz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-04-2010 10:48 AM |
Kernel Panic in 7.4.2 | dopewerewolf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-02-2009 07:48 AM |
Kernel Panic | Jon Thomas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-23-2005 10:55 PM |
