Old 05-27-2020, 01:54 PM
bluesfrequency bluesfrequency is offline
Default Re: Eucon 20.5 Automation Lag
I've reinstalled the updates and have narrowed the problem down to the Dock. If I remove it from the system, the S3 and Control app work just fine. No automation lag at all. As soon as I introduce the Dock, the lag happens on all attached Eucon devices.
Seeing as the Dock is the Central part of my workstation and transport controls, I would LOVE to see this address or a work around given.
Carlos Sanches
Re-Recording Mixer
Audio Circus
Warner Bros. Animation
http://www.imdb.com/name/nm0760851/
Old 05-27-2020, 07:28 PM
workingduc workingduc is offline
This is a show stopper for me as well.
Pro Tools Ultimate 2020.5.0
EuCon 20_5_0_149_10690
MacOS 10.14.6
Mac Pro 2009 upgraded to 2 x 3.46 GHz 6-Core Intel Xeon
32 GB RAM
Graphics Radeon RX 460 4 GB
3 LCD monitor setup.
No Avid hardware, Core Audio interface.
EuControl Surfaces:
3 Artist Mix
1 Artist Control
1 Avid Control, via iPad using Ethernet
All surfaces hooked up to a dedicated unmanaged switch with static IPs, and hooked up to the 2nd ethernet port on Mac, with EuCon System Pref set to 2nd interface.
I've done a proper removal of EuControl before 20.5.0 installation by running the uninstaller (as part of the installer DMG). I've also tried uninstalling, and choosing the option to remove all user prefs. Neither of these steps changes the behavior.
Session:
Large post mix session with DNxHD36 video.
686 tracks, but only a fraction of that are on-screen
25 VCAs, but not a crazy amount of nesting
Tried the various options about having tracks available for spill and layouts that are not onscreen, to no avail.
THE SYMPTOMS:
I touch a control, e.g. a fader, and 3 seconds later it starts writing automation. This is in a larger session, but even happens with all plug-ins disabled and CPU usage at 7% in PT System Usage meter.
In comparison, the onscreen GUI track faders work instantly -- automation starts writing.
If I roll Pro Tools and let it play for around 3 seconds, and then grab a control, it will (usually) instantly start writing the automation soon after grabbing the fader.
It also seems to be the case that if I remove all tracks from the Edit window display, paring down to only one track, the fader response is instant. Adding more tracks to the display (show tracks), eventually seems to cause the issue to appear.
Switched to older version of EuControl — 20.1.0.50_106700, and it works fine ‘cept for the fact that my Avid Control app on iPad is now newer, and there is now a “version mismatch.” So, the iPad is now unusable.
I can send my session for testing purposes if need be.
Thanks for your help.
Old 05-29-2020, 11:23 AM
So here's an interesting part of this bug. Try this, touch the fader BEFORE you hit play. For me, automation now starts writing straight away when the transport starts. If I wait to touch the fader after I hit play, it takes about 1 second for automation to start writing. I hope that helps Avid find and solve the problem in Eucon. Thanks in advance for solving this issue for us!!
Carlos Sanches
Re-Recording Mixer
Audio Circus
Old 05-29-2020, 02:37 PM
feakerboo feakerboo is offline
This is insane. Eucon is not at all usable for me right now. I have an s3/Dock/ipad and I've been considering upgrading to s6 but why would I even consider sinking more money into this system. Frankly Eucon was better a year or 2 ago. I have a 2 second lag when I hit the mute button, hit stop on the transport, I have a 4-8 second lag when I try to switch layouts. How in the world is this not getting caught in QA?
I'm sorry I usually don't usually complain publicly, but I can't do the mix I'm supposed to be doing right now b/c they are unable to get this system working. A system that was working flawlessly till a year or so ago.
Brad e
Partial Credits
Old 05-29-2020, 02:41 PM
Originally Posted by EddieJones View Post
For anyone that feels the need to roll back to 20.1 here's the ipa https://1drv.ms/u/s!AowqasI1coAD49BM...da4Tg?e=6kKham
This is unsupported though by Avid.
How do I use this?
Brad e
Partial Credits
  #16
Old 05-29-2020, 03:09 PM
I'm still seeing a touch of lag when the doc is offline, but it is much better for sure.
Brad e
Partial Credits
  #17
Old 05-29-2020, 03:13 PM
One other thing that has gotten worse over time is switching between different layout and spills. When I bought the system 2ish years ago, it was razor sharp switching from a one layout to another or to a spill. not the faders jump nearly a full second before the names change. -This is without the dock connected, with that nothing works.
Brad e
Partial Credits
  #18
Old 05-29-2020, 03:52 PM
I hope they can sort this out quickly. At the moment, looks like many of use are having to choose which peripheral to go without just so we can work. Not cool.
Carlos Sanches
Re-Recording Mixer
Audio Circus
  #19
Old 05-29-2020, 08:47 PM
MacOS 10.14.6
32 GB RAM
EuControl Surfaces:
3 Artist Mix
1 Artist Control
Session:
THE SYMPTOMS:
  #20
Old 06-01-2020, 12:01 PM
peapodpost peapodpost is offline
Roll back. Things here are OK with S1 & Dock on versions:
macOS 10.14.6
Pro Tools 2019.12 and 2020.3
EuControl 20.1.0.50
Control App 20.1.0.8
2018.7 Automation choppy with Eucon controller SFXgeek Artist Series 11 03-18-2021 09:06 AM
Logic 10.4.2 breaks Eucon automation modes. robertg Artist Series 25 05-19-2019 04:59 PM
Eucon/Artist Mix Trim Automation selection HotRats_Reloded Artist Series 1 10-06-2018 05:29 AM
automation mode glitch almost fixed in Eucon 3.4 ??? yoerik Avid S1, S3, Dock and Control App 7 09-05-2016 07:15 AM
PTHD 12.1 and EuCon automation reichman Artist Series 1 07-09-2015 10:45 AM
