Old 01-29-2014, 09:35 AM
puffin puffin is offline
Default HD ADR wipes generator
Hi folks,
I am looking to add wipes to my current ADR set up.
I feed HDMI to my LED monitor in the booth and it is all good with any common frame rate. What I would like to do is overlay wipes onto my feed from my BM deckling card. Is there a clean and sexy way of doing this?
I assume there is a midi triggered box that takes HDMI or HDSDI in and has a similar output but I have yet to find it.
Brian Power, CAS
Thehideoutstudios.com
Old 01-29-2014, 10:24 AM
Default Re: HD ADR wipes generator
Originally Posted by puffin View Post
Hi folks,
Brian Power, CAS
If you need to superimpose over your deckling out I think you need this:
http://www.endpointonline.com/products/vm15/vm15.html
Old 01-29-2014, 11:12 AM
dr sound's Avatar
dr sound dr sound is offline
At $3495.00 it is probably too expensive for his needs.
I have one of their devices a Jim Ketcham TC1128B Time Code
Box for our footage counter. Excellent gear and it's built like a tank!
if you can afford it his products are great.
I would demo the link I sent . Use it and see if it works.
Then rent it for 1 session. If it works great, buy it.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 01-29-2014, 11:48 AM
Streamers looks amazing! I may dump my video Sat rig as well as this is a great replacement.
Thanks Marti!
Thanks Frank as well, but I will save the 3k and put streamers on a new mac pro someday
Old 01-29-2014, 12:28 PM
yeah, thought you needed something for SDI/HDMI.
There's also EdiPrompt from soundsinsync. It's more expensive than Streamers but more aimed towards ADR needs.
Frank.
Old 01-29-2014, 12:50 PM
I thought I did too but this may be an excellent solution with no wiring changes.
Old 01-29-2014, 02:55 PM
kkfaudio kkfaudio is offline
I used streamers recently and it worked well, but I don't think it can overlay on the BM card - unless I missed something.
It works standalone synced to MTC from your PT session.
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 01-29-2014, 03:10 PM
minister's Avatar
minister minister is offline
Originally Posted by dr sound View Post
Great pice of software. Doesn't work with PCIe cards; you need to be using a floating window. He can't use his BM card with this.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 01-29-2014, 03:32 PM
garnoil garnoil is offline
That doesn't overimpose on the BM out of the PCIe (it only works on your desktop unless they have changed it).
Old 01-29-2014, 04:25 PM
I will keep the BM card for mix screenings but use the desktop for adr going forward and split the hdmi out of the second video card on my video playback mac pro. This is the slick solution I was hoping for.
Thanks!
Brian
HTML code is On
PT Wipes Away Without Any Notice/Pop Up !!! xiolablue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-19-2009 10:01 AM
Digi Dynamics III Wipes Out Waves Animation Lists hearttimes Pro Tools TDM Systems (Mac) 2 02-23-2006 10:16 AM
OS X 10.2.3 wipes out authorizations on the OS 9 Drive??? Jeff Schmidt Pro Tools TDM Systems (Mac) 24 01-15-2003 11:16 AM
ProTools system crash wipes out my startup in XP RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-29-2002 11:01 PM
I want to trigger GPI "Wipes" with PT etboivin Pro Tools TDM Systems (Mac) 1 07-25-2000 04:34 PM
