Old 08-24-2009, 09:12 AM
reycantong reycantong is offline
Default Re: How to Master with LE 8?
Originally Posted by Keybeeetsss View Post
For mixing?
Yes. There are actually some presets there that are specifically for acoustic guitar, vocals etc...
You can use the eq, compressor etc individually on a specific track.
Old 08-24-2009, 09:52 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
I hear ya...(no pun intended)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-24-2009, 12:57 PM
MrWillsi3 MrWillsi3 is offline
So quick question, when i do my original bounce from my final mix....i want to make sure the master is NOT clipping, correct? I also heard i should want to peak between -3 and -6 DB on the Master fader...so to get this i can simply just lower the master fader so that i get a peak around that area right? (I tried using the ALL setting and lowering all my tracks some, but if i have any automation, it just goes right back up).
Then as far as dithering, do i put it in then, or during the mastering process....and finally...when i master i should have ALL my bounces together, correct? So when i get all the levels right, do i just make all but 1 track inactive, and bounce it, and then continue to do that till i have rebounced all my tracks?
Old 05-02-2012, 10:23 PM
cyprienmenendez cyprienmenendez is offline
1.I try to get my mix not over -6db.
2.I export it without dithering as 2 mono tracks same bit same sample rate.let the master fader at 0 db (no automation on masterfader) no plugs except TT RANGE DYNAMICS for example
3.I create a new session same bit same sample rate import my 2 mono tracks.
4.Following the needs
a)equalisation
b)compression
c)Stereo Field
d)limiter
e)Dither
But less is better....
5.Try to get yo master under -0,3db or -0,5db for security.
NB: all the levels in db are approximative coz you must use your ears first.
Old 05-03-2012, 10:18 AM
RegenerationMix RegenerationMix is offline
Originally Posted by Torchlight View Post
I use Waves Mastering Plugins (LinEQ, LinMB, L2) for all my mastering and have never been sorry.
+1
I use Waves Native power pack for mastering. great plugs.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Production Master Or Original Master Zelos General Discussion 3 02-14-2011 07:52 PM
Fixing Clipping in Master in Master Fader pakobo7 Pro Tools M-Powered (Win) 10 09-16-2006 10:53 AM
TC Master X or Waves Master Bundle TiPo Pro Tools TDM Systems (Mac) 4 02-15-2003 11:41 PM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
Master Fade & Master Plug Ins Kenny Gioia Tips & Tricks 10 04-17-2001 02:39 PM
