CPU -9173 Error [Solved potentially]
Hi folks,
Like many of you, I have been plagued with this pesky -9173 error. Reading those afflicted, I too thought my machine had plenty of CPU cycles left for audio usage. For the past few weeks, I have been locked in on a session from around 5am-10pm each day so I had a good repeatable project and environment to perform some tests, and so resolved to try and find what this issue was related to. The good news is that I may have found the issue. Using Terminal.app, Console.app, iStats Menus and Activity Monitor.app to monitor what the system has been doing, I started to see some patterns. After doing all the reinstalling of PT, removing and reinstating plugins, trying difference drives, trying different audio i/o, it appears that the very helpful app called Flux.app is the culprit. Flux.app is a simple utility that changes the colour temperature of your monitor to mirror the time of day. So early the morning and into the evening the monitor progressively gets orange. Its a brilliant way of reducing fatigue and makes long sessions a little less onerous. However, it seems that its making Sysem calls to the WindowServer, and when it does this there must be an OS X API snafu as the system locks for a moment, and the poor old AAE chokes and then reports this error. This explained why I was seeing more -9173 errors in the early mornings and evenings. Once identified, this -9173 error correlated directly with the "WindowServer" entry in the console.app. The remedy, was to simply delete Flux.app, restart, and get back to mixing. I was sad to lose the automatic orange colour temperature, but this is easily reproduced by creating a custom monitor calibration in the Display pane of the Preferences.app Whilst I am sure there are a multitude of reasons why the AAE could choke and report the -9173 error, for me, I have managed to completely remove the non-session caused ones. Hope this helps some of you. Best, Tony |
Re: CPU -9173 Error [Solved potentially]
This got my hopes up for a second...but I don't have a flux.app on my mac to delete. I assume this is a 3rd party app you were using?
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
I'll try to see if I can find a pattern. I use Flux, hard to live without it, and yes I got a ton of 9173s and 6101 as well...
PT 12.7.1 @ OSX 10.12.1 RME Babyface Pro - MC Control V1 |
You can use Apple's Monitor calibration tool to create a profile that has the same colour temperature as Flux.app
-9173 error in PT 12 | ArKay99 | Pro Tools 12 | 10 | 06-11-2016 01:41 AM |
Pro Tools 11.1.0 AAE-9173 Error | justus1900 | Pro Tools 11 | 4 | 12-22-2015 02:46 PM |
Error -9173 | music.m | Pro Tools 11 | 1 | 03-19-2015 09:42 AM |
CPU error 9173 when bouncing to MP3 | jamisbegby | Pro Tools 11 | 2 | 03-01-2015 10:48 PM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
