Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-14-2019, 08:02 PM
Raoul23 Raoul23 is offline
Default Slate drums SSD5 can it be wrapped??
With the upgrade price being so cheap I’m wanting to upgrade from SSD4 to SSD5 but being on ProTools 10HD it won’t work being AAX64. I’m wondering if there is a way to wrap it and use in ProTools10 at the mo??
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-14-2019, 08:49 PM
Default Re: Slate drums SSD5 can it be wrapped??
None that I can think of that will wrap AAX-64.
But SSD comes in multiple other plugin formats and you can wrap them with wither BlueCat patchworks, or run them separately in Vienna Ensemble Pro.
But getting rid of Pro Tools 10 might be a good idea as well.
Old 04-14-2019, 09:24 PM
Thanks Darryl
I’m a bit to heavily invested in PT10 HD at the mo to upgrade and move on.
Raoul Crane
Old 04-14-2019, 11:46 PM
Sardi Sardi is offline
As Darryl said, run the VST version in Patchwork as that is available as RTAS and also AAX32 from memory.
Old 04-15-2019, 05:19 AM
crizdee's Avatar
crizdee crizdee is offline
How can you wrap a 64bit VST to a 32bit RTAS/ AAX? there is no way that i know of, but would be great if possible.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-15-2019, 06:18 AM
Originally Posted by crizdee View Post
Chris
Ah crap. It didn’t even cross my mind that it would be a 64bit only plugin.
Yes you’re right. Unless there’s a 32bit VST/AU version, then no, it won’t work.
Old 04-15-2019, 02:49 PM
Bugger
Raoul Crane
Steven Slate Drums 5 (SSD5 and SSD5 FREE) Now Available! unkJE The Drum Room 15 05-28-2020 11:53 AM
Troubles with Slate SSD5 glasswing Virtual Instruments 4 01-14-2019 06:34 PM
Instrument tracks, SLATE SSD5 glasswing Virtual Instruments 4 12-31-2018 06:52 AM
FS: Slate Digital, Steven Slate Drums, Eventide, Softube sadateffendy Buy & Sell 7 08-11-2016 05:14 PM
Slate Digital and Steven Slate Drums AAX DHL AAX Plug-ins 6 04-22-2013 12:50 PM
