Old 03-05-2019, 01:22 PM
Raoul23 Raoul23 is offline
Default Strange LED display
Every now and then my 16-24 LED display becomes dimmer than the rest. This isn’t all the time. Is my LED strip on the way out do you think?? I’ve included a pic
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-08-2019, 07:17 AM
MusoPro's Avatar
MusoPro MusoPro is offline
Default Re: Strange LED display
Did you run a LED test? Then you can visually spot where any problems are.
Whenever my C24 starts freaking out I reinstall the latest firmware. You need to restart the unit while holding down the 3 buttons above the fader it will then update.
Then you’ll need to go Peripherals and find ur unit.
Good luck!
Mitch
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
Old 03-09-2019, 03:09 AM
mups mups is offline
The Control 24 and 002 typically have problems with Digidesign's cheap harnesses because the contacts go bad over the years.
This is solved (temporarily) by disconnecting the harness, cleaning the prongs with scratchy sponge or sand paper, replugging with contact spray.
Could be the same thing here...
Old 03-09-2019, 07:54 AM
Thanks I’ll give that a go
Raoul Crane
Old 03-09-2019, 08:35 AM
Rich Breen Rich Breen is online now
I would not use sandpaper. A very mild abrasive like a pencil eraser is a better choice to remove the oxidation, a duster to remove any eraser particles left over, then clean with isopropyl alcohol, then perhaps a contact enhancer like De-oxit.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
new Logic X bug - strange text in plug-in display robertg Artist Series 0 02-10-2016 12:11 AM
Strange character display on Profile noclevername VENUE Live Sound Systems 2 07-02-2014 10:09 PM
strange display issue MC Mix (Euphonix) nstu Artist Series 0 02-18-2012 06:03 AM
Digi Tech Sup: Color Display & Aux Send Display bugs nob turner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-07-2010 02:43 PM
Strange session state - display frozen, play/record strange pkcraft Pro Tools TDM Systems (Win) 2 06-04-2007 02:43 PM
