Old 09-02-2020, 09:11 AM
MixerGuy MixerGuy is offline
Default Catalina not seeing Plugin Settings (but knows they are there)
Hi all
Brand new Mac Pro. Did *not* do any data import (data migration i mean)
So I want my various plugin "presets" that I have made over the years from my old Mac (Sierra) to be on the new MacPro.
So on my new Mac Pro (Catalina) I tossed out the Plugin Settings folder and brought in my old Plugin settings folder.
[ProTools Plugin-Settings files are at:
Documents / ProTools / Plug-In Settings. (Folder)]
and then... even after tossing ProTools prefs and restart and launch ProTools - each plugin wont see my presets.
even weirder - if i tried to manually import just one of my plugin presets inside any plugin - I get the attached error message - see attached image - so somehow ProTools SEES the plugin settings (and wont let me import a single one) but it wont show them in any plugin. Weird!
anyone else see this?
OS 10.15.5
PT 2020.5
any guesses as to an easy fix?
thanks!
Old 09-02-2020, 09:13 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Catalina not seeing Plugin Settings (but knows they are there)
Double check your user settings and re-set that path, it may do the trick.
Janne
Old 09-02-2020, 09:22 AM
Thanks - can you elaborate please?
Not sure what you mean by check my User Settings..... my plugin settings just are not visible in any plugin.
and what do you mean by re-set that path?
thanks
Old 09-02-2020, 09:24 AM
JFreak's Avatar
Setup / Preferences / Operation / User Media and Settings Locaton
Janne
Old 09-02-2020, 09:25 AM
JFreak's Avatar
I have mine in iCloud so whenever I reinstall, I just point that to iCloud and that is it
Janne
Old 09-02-2020, 09:49 AM
Marsdy Marsdy is offline
Originally Posted by MixerGuy View Post
Hi all
OS 10.15.5
PT 2020.5
thanks!
Could be you need to give Pro Tools permission to access your Documents folder in Mac OS System Settings?
Dave Marsden
UK
Old 09-02-2020, 10:07 AM
That would make sense..... thanks..... I'm new to Catalina - how would I do that?
many thanks.
Old 09-02-2020, 10:14 AM
many thanks.
Not 100% sure I'm afraid! When I first ran PT on my nMP it asked for permission to access my Documents folder which I granted.
Maybe you can do it manually by going to:
System Preferences>Security and Privacy>Privacy tab>Files and Folders and adding Pro Tools there.
Dave Marsden
UK
Old 09-02-2020, 12:06 PM
Update: problem solved - thanks Dave!!!
I had to go into System Preferences>Security and Privacy>Privacy button >Files and Folders ….. and adding Pro Tools there.
YES - this was the fix - the Documents Folder here was not selected… so I did…. Fixed the problem. Whew!
It was not selected by default. Tho PT was....
screen grab attached BEFORE I clicked on Documents. (to make it then work)
Old 09-03-2020, 02:23 AM
Glad it worked out! Strange Pro Tools didn’t ask for access to your Documents folder when you installed it or ran it for the first time.
Dave Marsden
UK
Safe way to move all PT Plugin Settings from old rig Sierra to new rig? (Catalina) MixerGuy Pro Tools HDX & HD Native Systems (Mac) 7 09-01-2020 02:35 PM
Catalina Plugin List Siegfried Meier Pro Tools 2019 2 02-07-2020 07:38 AM
Plugin Settings Johnny Hulst AAX Plug-ins 6 04-24-2015 04:22 AM
Plugin settings Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-21-2004 01:28 AM
Has anyone got any Plugin settings for NT TDM tonygoodall Pro Tools TDM Systems (Win) 4 03-26-2001 01:29 AM
