Old 03-07-2008, 11:39 AM
headphono headphono is offline
Default memory usage?
Howdy,
I'm using ProTools M-Powered version 7.1.1 on a Windows XP pro system. I am currently using 2gB of DDR2 533 ram. I want to max out my motherboard to 4gb of ram, but was not sure if this version of PT will actually utilise it all.
Not a fan of wasting money, so does anyone know if this version of PT will actually make use of this much Ram?
I don't want to buy ram that the software won't actually use, but would like to upgrade ram so I can use plugins a bit more freely without worry of hitting walls.
Anyone?
Jacob
Old 03-07-2008, 11:49 AM
spkguitar's Avatar
Default Re: memory usage?
It's not Pro Tools that will not utilize it, it's Windows XP.
However, with that said, various DUC users have found through testing that even though Windows can not technically use anything over 3GB, having 4GB installed does offer slight advantages and improvements.
Another thing to note; adding more memory is only helpful if you are using plugins that actually use the memory, such as samplers and/or convolution reverbs. Most standard audio plugins (EQs, compressors, etc) will not see a benefit from increased memory. Upgrading the CPU would help more with overall plugin count and strain onthe system from large sessions, but memory only helps with sampling type plugins that utilize memory.
Old 03-07-2008, 12:29 PM
Thanks for the reply. Although I'm aware that XP Pro will only use 2 gigs of vitual memory, the 3 gig switch in the boot.INI file will allow windows to address 3 gb of memory if the software (protools) is coded to use 3 gb of memory
Does anyone know if this is the case?
Jacob
Old 03-07-2008, 01:41 PM
spkguitar's Avatar
Yes.
It is exactly what I meant when I said that.
The answer to your question is "Yes".
Old 03-07-2008, 06:03 PM
Alright,
Thank you!
Jacob
RAM memory usage in PT9 / MAC OS Eekay macOS 45 01-20-2011 06:39 PM
64-bit memory usage Ben Hunt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-07-2010 03:29 PM
Why does memory usage go up every second? brianjanthony Pro Tools TDM Systems (Mac) 11 11-07-2006 09:07 AM
Memory Usage gg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-11-2003 01:39 AM
memory and cpu usage gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2001 02:30 PM
