Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-25-2018, 02:48 PM
Tahini Tahini is offline
Default Can't disable encryption to make Pro Tools First upload
A search of the knowledge base to get Pro Tools First to upload to the cloud when I exit the software led me to this solution, but I can't do it:
It said that if I was getting error PT-204847 ("There was a problem uploading the project,") then I should right-click the Pro Tools folder and disable encryption. I found my Pro Tools First folder, right-clicked it, and hunted for any option to disable encryption. What I found was a check box called Encrypt Contents to Secure Data. It was in the Properties folder under the General tab. But the check box was already unchecked!
So I still cannot upload when I exit out of my Pro Tools First, sadly. I did check the activation and it has gone through. Not sure what to do next, other than export each track to some location on the computer every time I want to exit out of Pro Tools First. Is there another way of saving my work? Is there something I haven't done to get a project to upload? Here is my computer system info:
I have an ASUS notebook with a Windows 10 Home system, the operating system is 64-bit with 16 GB of RAM and an Intel Core i7 processor at 2.70 and 2.90 GHz. It is supposed to be compatible according to the Avid website.
Befuddled,
-- Tahini
Old 06-26-2018, 05:52 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Can't disable encryption to make Pro Tools First upload
Try running Pro Tools as Administrator(see http://duc.avid.com/showthread.php?t=300050 for instructions)and turn of Virus protection and firewalls ,PT doesn't like these.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Can I upload tfx presets without Pro Tools? ruspang Eleven Rack 6 12-30-2011 12:48 PM
How Can I Disable My Computer To Make Mbox2 My Soundcard? Dowlzy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-22-2008 03:36 PM
how to make a midi track "mute safe" i.e. disable? c-post MIDI 3 11-22-2004 08:30 PM
how to make serial port available for machine control and disable it's MIDI function? c-post Pro Tools TDM Systems (Mac) 7 08-05-2002 12:49 AM
Pro Tools Free Unable to Upload TD7-NYC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2001 10:56 AM
