Old 05-20-2019, 11:45 PM
[email protected] mjr@du.se is offline
Default Displaying input/preamp is slow
We're using remote preamps (both Avid PRE as well as Focusrite RedNet) which is working fine when controlling from the Preamp Track View within Pro Tools.
When displaying the Input/Remote Mic Preamp button on the Process Module on all tracks we're seeing a noticeable delay populating the values of the knobs. Typically the first track is almost instant but then a delay for several seconds before the other tracks light up. Once populated switching to Inuput is instant going forward so it seems like the values are cached.
I remember seeing something about this maybe getting fixed with the plugin parameter caching in 2019.5 but I'm still seeing the issue in the new version.
Are there any preferences for this that I'm missing?
Old 05-21-2019, 05:55 AM
creativecontrol's Avatar
Default Re: Displaying input/preamp is slow
Please try the preference Settings > User > Knobs: Pre-Load All Knobs On Session Load. This option should help with displaying function views on knob modules, especially when doing so all at once with the All switch enabled.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2019, 11:53 PM
Yes, I've turned that feature on but I don't see any changes to performance at all. There is still a noticeable delay when switching to Input.
I've tried both directly after creating the tracks and after closing and re-opening the session (if the "on load" would help) but see the same behaviour both times.
Old 05-24-2019, 04:23 AM
Thanks. I’ll make sure this is logged with QA.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-27-2019, 04:15 AM
Great! Thanks Jeff!
Let me know if you need any more information or want me to test anything.
Old 06-05-2019, 10:06 AM
hixonjames hixonjames is offline
It's the same for me. I have another thread about it here: http://duc.avid.com/showthread.php?t=400652
Since the 19.5 update, the Insert, EQ, and Dyn functions all come up instantly now. But Input is still slow.
James Hixon
Pro Tools | HDX 2019.5
S6 M40 19.5
Mac Pro (Late 2013) - Mojave 10.14.5
3 GHz 8-Core Intel Xeon E5
64 GB RAM
Old 10-25-2019, 02:12 AM
I just installed the latest version (version 19.9.1) on our S6 M10 and I'm still seeing the same behavior - when switching to Input the loading of parameters from our Avid PREs take several seconds to show up on the surface.
We have "Pre-Load All Knobs On Session Load" active but it makes no difference.
Old 10-28-2019, 04:10 PM
I believe this is known and logged but I will double check. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-05-2019, 06:02 AM
Confirmed, reproducible and logged.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
PT IO Control Panel not displaying info on "input" Tab Andres22 Pro Tools | Duet & Pro Tools | Quartet 4 04-20-2019 01:43 AM
Slow graphics when displaying Avid plug-ins Paul Maunder Pro Tools 12 48 09-23-2016 11:09 AM
input 11-12 on apogee ensemble thunderbolt not displaying in protools 11 Matt Darcy Pro Tools 11 3 09-13-2015 01:35 PM
Input Volume Displaying Incorrectly ( -5 db) Zeally Pro Tools 10 5 03-29-2015 12:50 PM
Aux Input vs. Mic 1/Analog 1 Input (when using external preamp) xesands 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-26-2010 08:27 AM
