Old 05-17-2019, 04:38 AM
Default Re: Sample Rounding Issue!!!!
Originally Posted by innesireinar View Post
I wonder how other users do when arranging midi material since posts like this are not so interesting. From my point of view this bug is something that drives me to migrate to other DAWs if not fixed soon, or at least to back to PT11 definitively. Unfortunately PT11 doesn't work on OS newer than Yosemite and some today plugins want at least Sierra.
Actually PT 11.3.2 works just fine on OSX10.12.6. The only known issue is that you can't import audio via the drop down menu item but it can be done by drag and drop from Finder. Been with PT 11.3.2 inside OSX 10.12.6 aka Sierra for about a year now. There's a difference between not supported and won't work and this is one of those.
Do this: make a clone of your system using Carbon Copy Cloner (you do have clone backups of your system right?). Create a second partition on your system drive. Install OSX 10.12.6. Install your music s/w. Work in PT minus the import issue.
Jack
QAPLA!
Old 05-17-2019, 05:01 AM
foxes's Avatar
foxes foxes is offline
Agreed, this bug has me at the point. As I have said, Avid have until my sub runs out in October, if this bug is still an issue in PT tools then I'm moving to Studio One 4 (I have several friends using SO4 & they love it & wonder why I put up with PT lacks ie no ARA2, track folders, drag & drop etc).
This basic necessity functionality bug has just compounded my frustrations with PT, I have stuck by Avid giving them my sub payment every year hoping they will implement at least ARA & FIX THIS BUG. What we get are some updates that give us features the other DAWs have had for ages, PT is just too behind the competition
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
Old 05-17-2019, 05:47 AM
innesireinar innesireinar is offline
I already have 2 partt on my sys disk, one with yosemite and the other with HS. I should try to upgrade yosemite to Sierra. But when I reinstatiated to vs 12.x and 2018 I had some strange issues at buffer below 256. I also had this issue with HS until the 10.13.6 that resolved this issue. A session with audio files only with no plugins inserted showed cpu spikes, that went away by closing the edit window. Weird. I don't know how the 11.3.2 works on sierra about this problem.
http://duc.avid.com/showthread.php?t=398805
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 05-17-2019, 05:54 AM
I totally agree with you about how Avid is far behind its competitors and full of bugs, furthermore this annual "tax" we have to pay them for being beta testers. But when mixing PT is still the best tool. I was thinking about a system with a modern daw, like cubase, S1, etc on a computer that send digital signals to another computer for mixing in PT. But it is too complicated.
Old 05-17-2019, 08:33 AM
Don't have any cpu spiking problems but then again I don't run under 256 buffer. And I keep the edit window open all the time as well as the mix window. Sometimes 60+ tracks audio with plugins on busses. My system details are in my profile page.
Jack
QAPLA!
  #16
Old 05-18-2019, 02:17 AM
It seems that this issue was related to the HDX only
  #17
Old 05-18-2019, 03:49 AM
foxes's Avatar
Agreed.
I have mixed some of my best work in Logic 6,7, 8 & 9. When Apple took over I got worried 😬 then they turned in X (10) then mixing in Logic became s***
PT is indeed great for mixing but by no means IMHO the ultimate for it. For me I will mix in what will be my primary DAW & in time depending Avid that may be Studio One.
  #18
Old 05-19-2019, 07:24 AM
I was hoping that in future releases Avid would have fixed the sample rounding error on audio. Instead since PT 12 they have introduced this error on midi as well. Unbelievable
  #19
Old 05-19-2019, 04:13 PM
foxes's Avatar
I know, you'd think they should know what they're doing......
  #20
Old 05-19-2019, 05:01 PM
Today I installed the 10.12.6 on another disk and installed PT 11.3.2 but it doesn' t recognize the HDX. I've also tried to install the pt12.6 driver but with no success. At this time on Yosemite I have problems with NI stuff that want at least the 10.11
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 02:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
