Old 05-12-2019, 07:49 AM
ThomasHQ ThomasHQ is offline
Default Can't close EQ plug-in windows from mix surface with Eucon 19.5
Hi all,
When opening an EQ with the EQ button on the Artist Mix, the plug-in window opens, but when I do like I've always done in the past, pressing the PAN button to close the plug-in, nothing happens. I have to close the window manually. Anyone else having this issue?
Well, actually, while writing this I noticed that I can in fact close the window by pressing the Shift button and PAN. The problem with that is that I then have to hit the PAN button one more time to exit since Shift + PAN open the mix assign view.
Best regards,
Thomas
Old 05-12-2019, 09:47 AM
BScout BScout is offline
Default Re: Can't close EQ plug-in windows from mix surface with Eucon 19.5
Can't help you with your exact issue but to close a plugin, I go
  1. Inserts
  2. then turn off "SEL" for that plugin.
Old 05-12-2019, 11:44 AM
Hi! Thanks for taking your time to help me out. That works well if I mainly stay in Inserts + Channel view. But that would mean I have to change the way I like to use my Mix units, or it would mean doing 5 button presses to close a plugin instead of just one.
It seems I have to change my way of working, and changing my templates every time AVID makes a major new release, and it's becoming a bit frustrating.
Best regards,
Thomas
Old 05-13-2019, 09:20 AM
EddieJones's Avatar
When you press Pan does the Pan window open? With the new Pan and Send Window functionality workflows a lot of users wanted the plugin window to stay open whilst they were also using Pan and only close when you go to a different Track.
Also what setting do you have the Open Windows setting set to in EuControl ? Just Plugins or with Pan (and Sends)
Old 05-13-2019, 03:14 PM
Hi Eddie,
No, when I press Pan the pan window doesn't open. I have the open windows set to plugin only.
Could this have something to do with what you have had to do to make Mojave work? I'm still on Yosemite because it's been rock steady for me and I haven't dared to move on from there yet.
Best regards,
Thomas
Old 05-14-2019, 04:25 PM
Personally, I'd go back to the last version of Eucon until this gets sorted
Old 05-15-2019, 01:27 AM
I wish I could go back but since I'm using the Control app for iPad, that is not an option. If only I had turned off auto update!
Old 05-15-2019, 07:49 AM
EddieJones's Avatar
This will be made better in the 19.5.1 release we are trying to get out in the next couple of weeks.
Old 05-15-2019, 09:40 AM
Thank you Eddie, I'm looking forward to that!
Keyboard shortcut to close active plug-in window? Muddy-T Tips & Tricks 5 09-12-2016 02:02 PM
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
Key command to close audiosuite windows? jeremyroberts Pro Tools TDM Systems (Mac) 0 11-14-2005 05:01 PM
New Mastering EQ Plug ..December 24th is close.... Alécio Costa Pro Tools TDM Systems (Mac) 4 12-12-2003 02:00 PM
Quick Keys-close plug in window flipmodal Tips & Tricks 3 02-09-2002 03:50 AM
