  #21
Old 10-08-2018, 04:42 PM
robertg robertg is offline
Default Re: Logic 10.4.2 breaks Eucon automation modes.
Originally Posted by EddieJones View Post
Can you set it to Transport Jog on both but the commands to Jog on Jog and Shuttle on Shuttle. (I'm on holiday now for a couple of weeks but will try and get our Appset from the QA guys)
Tried that. I got the Jog lit constantly but no movement, even after I pressed the button. After I pressed Zoom H and turned the knob a bit, I went back to Jog. It started to jog, but can't be turned off again, the light never changes either.
Can this be fixed in the next software update?
  #22
Old 11-20-2018, 04:05 PM
Hi Eddie, I wanted to circle back on this outstanding issue with the wheel mode inconsistency. I've posted a video that shows the jog light never goes out, and that the zoom H and V buttons require 2-3 presses to go out. This is regardless of whether or not the buttons are configured as transport or dock mode, it's still a bug that hinders workflow because you can't tell at a glance what mode you are in. Can this be investigated fully and added to the fix list? Thanks for looking into it
https://www.dropbox.com/s/sez8vgq9ip..._0180.MOV?dl=0
  #23
Old 02-01-2019, 12:39 PM
I am bumping this thread. Eddie, are there no plans to fix the lights at the right of the dock wheel?
  #24
Old 04-19-2019, 11:22 AM
EddieJones's Avatar
Robert, can you try deleting the jog and shuttle commands from those keys. They will then default back to the direct Jog and Shuttle commands and not use the (bad) softkeys.
  #25
Old 04-22-2019, 10:40 PM
After doing that they only flash green briefly when pressed, but nothing happens.
  #26
Old 05-19-2019, 04:59 PM
In the latest Eucon version, clearing the button commands has fixed the issue.
Thanks!
Global Automation Modes (and more...) PatrickCusack Avid S4/S6 1 04-10-2018 09:36 PM
System 5 MC Automation Modes Mike Hybrid System 5 6 07-10-2014 02:14 PM
How to program track automation modes noeqplease Artist Series 0 05-23-2011 03:44 PM
change automation modes? Richard Fairbanks ProControl, Control|24, Command|8 2 07-11-2007 04:02 AM
bcf2000 & automation modes?HOW? maltezze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2006 06:59 PM
