Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
  #21
Old 10-14-2016, 04:00 AM
DeepStar's Avatar
DeepStar DeepStar is offline
Default Re: Pro Tools First error -6117
Originally Posted by BitBasher View Post
Ran in to the same thing after updating to the latest patch of Pro Tools First. Unfortunately the program is not very user friendly at all and allow you to change your settings before Pro Tools loads even while holding down the N key. What fixed it for me was the following: 1) right-click on your speaker icon at the bottom right on your taskbar
2) choose "Playback Devices" 3) disable all the devices except for your Audio Interface you use for recording (ASIO4ALL in your case) 4) Start Pro Tools First and it works
Apparently Pro Tools First is trying to open another device on startup which causes the loop
Hi All
I just wanted to confirm the fix stated above worked for me on Win 10 x64 PT12.5. Nothing else worked until disabling all other audio devices.
Regards
DeepStar
Pro Tools 12.5
Gigabyte Laptop
Win 10 Home x64
Quad Core i7 16GB
Komplete Audio 6 I/O
  #22
Old 11-15-2016, 04:23 PM
Leefie Leefie is offline
Originally Posted by El Buey View Post
I had this same error message. Using Pro Tools First...came free with a Focusrite 2i4 audio interface. I contacted seller (Sweetwater) regarding error message. They told me I needed to turn off all playback and record audio settings on my laptop. I did, error message went away and I was able to finish installing Pro Tools First.
WORKED FOR ME!!!
Brilliant!!!
  #23
Old 04-10-2017, 01:26 AM
RuudNL RuudNL is offline
After trying many times before, today I tried again to install Pro Tools First.
I followed the hints in this thread, disabled all soundcard inputs and outputs that I was not going to use, but still...nothing!
Pro Tools First says it doesn't find any audio hardware. (And then ends before showing me any further options...)
That's strange, because all other audio software on my PC works perfectly!
Pressing (or holding) the 'N' key doesn't have any effect.
For now I have deleted all Pro Tools First files and I hope there will be a GOOD solution for this problem that works.
  #24
Old 04-10-2017, 04:49 AM
Southsidemusic's Avatar
Well since we have no info on your system we cant really help you much ..
Read this and post back all the info needed.
http://duc.avid.com/showthread.php?t=300050
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #25
Old 04-10-2017, 05:15 AM
No problem! I continue happily with Reaper...
  #26
Old 05-06-2017, 01:06 PM
Ryan_H Ryan_H is offline
Hi Guys,
I am having the same problem and I can't believe it hasn't been fixed by now!
I am running Pro Tools First on my HP laptop and it is connected to my audio interface (Focusrite Scarlett Solo). I know for a fact that the AI works fine because it works perfectly alongside other software.
I've tried holding down "N" to bypass the normal boot procedure and so far no luck.
I'm extremely disappointed that its got this far to be honest, I've been trying to fix this for over a month now!
Anyone able to help????
Much Appreciated,
Ryan_H
  #27
Old 05-07-2017, 12:08 PM
After a lot of problems I finally got it working.
(Removed all Windows sound devices and installed Asio4all first.)
The problem in my case was that the ASIO buffer size wasn't a multiple of 32.
(I think it was 528 or so. Other DAWs don't have a problem with that.)
So I got it working, but I removed Pro Tools First already because:
- You can't exchange projects with other Pro Tools users.
- You can't store projects locally, only 'in the cloud'.
- You can only record a limited number of audio sources at the same time.
So Pro Tools First is only suitable to 'get an impression of how Pro Tools works'.
Unfortunately, that is not good enough for me...
PT First AAE Error 6117 epicsaxman13 Pro Tools | Intro Discussion 10 06-18-2016 05:28 PM
Pro Tools First Error -6117 MinusE Pro Tools | Intro Discussion 1 08-31-2015 01:36 PM
Audio Error 6117 PT First laurabeele Pro Tools | Intro Discussion 3 08-13-2015 11:34 AM
Unable to reacquire hardware and DAE error 6117. Please help TheSmackPanda Pro Tools 10 2 06-16-2015 02:02 PM
