Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 10-06-2015, 03:43 AM
nortle nortle is offline
Default Fast Track C400 pitch / sample rate problem
Hello,
I experience the following problem since I bought the unit 1 1/2 years ago and it's quite annoying. Finally I found the way to this forum (since Avid seems to try everything to avoid help or serious driver updates).
The problem:
Restart the Computer. The whole audio output is now pitched a few semitones higher. This happens irregular. Sometimes it happens, sometimes it won't. Tried to find a scheme, but there is no.
Go to C400 Control Panel -> Setup -> Samplerate
Switch to 48000 and back to 44100.
Problem solved.
This appears on Windows 7, 8 and now 10. Tried different driver versions (of course also the most actual).
Anyone out there who has the same problem? I think that's a No-Go for a "Pro" audio unit. Or may it be that my unit is kind of "broken"?
Thanks for any contribution to this issue.
Old 10-06-2015, 06:19 AM
JoelG's Avatar
JoelG JoelG is online now
Default Re: Fast Track C400 pitch / sample rate problem
Do you have the C400 set as the default playback device for Windows? If so, that could be part of the problem. Personally, I have my audio interface set to be used by my DAW only, and run an output from it to my sound card, speakers connected to the sound card. This prevents a lot of problems with Windows/iTunes/YouTube etc. taking over the audio interface while you're trying to record.
If you have a session set @ 48000 and Windows wants to play a sound, it will likely be @ 44100, and mess with the interface.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 10-06-2015, 06:47 AM
Thanks for the answer.
Yes, it is the standard device. That coiuld be part of the problem.
So I should connect my (onboard) sounds output with the input of the C400 to get all the non-daw sounds? Isn't there a loss in quality?
Old 10-06-2015, 09:57 AM
JoelG's Avatar
Here's my connection setup, if it helps:
Audio interface set in DAW, Creative sound card set as default Windows audio device.
SPDIF out of interface to SPDIF in of Creative (you could use analogue in/out)
Monitors connected to output of Creative
This way your interface is left alone to do DAW related tasks, but all audio is still passed through to your speakers.
Joel
Jam Space:
Home:
Rig:
Fast Track C400 - general problem with driver? Ibo81 FireWire & USB Audio Interfaces (Win) 12 05-12-2016 03:17 PM
Audio Configuration Problem - Fast Track C400 + Studio one 2.6 joaocavanus FireWire & USB Audio Interfaces (Win) 1 03-13-2014 05:16 AM
Problem with M-Audio Fast Track C400 Ohio21 FireWire & USB Audio Interfaces (Win) 2 08-19-2013 12:56 AM
Keystation 61es MIDI problem, Pro Tools SE, Fast Track C400 KidA8787 FireWire & USB Audio Interfaces (Win) 0 07-11-2013 12:56 PM
Help! Please? M Audio Fast Track Sample Rate PT9 HD acmost macOS 0 02-05-2013 03:33 PM
