Mbox 3 pro crashing/disconnecting
Hi
I just upgraded to the Mbox 3 pro from the Mbox 2 pro. It works great when connected but the thing is after not using it for some hours, lets say overnight I find it every morning with the power light blinking and the device disconnected. I have to re-plug the firewire cable in order it to work again and sometimes reboot, its frustrating. I tried it with different firewire cables, but no luck. I'm using a PCI-express card for the firewire connection. The weird thing is that i had the exact same issue with my old Mbox 2 pro. Anyone knows whats the problem? please help, i'm lost. Thanks a lot. |
Re: Mbox 3 pro crashing/disconnecting
Hi and Welcome to the Community
You probably have the computer set to the sleep function which is NEVER a good idea with PT or any DAW for that matter.δ When you are going to be away from the computer for a while you have to shut everything down and restart in the morning when you want to resume work. Shut off any power saving and sleep function and never use that again for music purposes,
Hi Christopher
Thanks for the reply. Where do I change these settings? In windows 7, my desktop was set to no sleep in all categories through the advance power settings menu. but the Mbox keeps crashing. So what you are saying is that its not possible to leave the Mbox pro running for 24/7 without it disconnecting after some hours not being used? Thanks again |
As we use Mac and i haven't owned a PC since 1997 i would ask someone else to chime in so this can be cleared up. So you don't have any snooze or sleep or pwer down management activated right?
Nope, the only thing that goes in to sleep-mode after an hour, is the computer monitor.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I tried both, still disconnects
Temporarily disable any Anti-Virus software until restart. If that doesnt fix it Disable Network Adapters (get off the Net!) and all the other tips from Windows 7 Optimizations and Troubleshooting http://avid.force.com/pkb/articles/e...oting/en349411
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6 Laptop + 24 BENQ GL2450-B + Samsung 27 CT550 curved Monitor * best Wife! |
I tried almost everything :/
still crashing overnight its frustrating |
Telling us you "tried almost everything" tells us nothing. Tell us exactly what you tried.
What exact Firewire adapter are you using? Is it a recommended model like a SiiG using a TI chipset? Eitherway I would beg/borrow/buy a new FW card and try that out. Although certainly not as bad as say the fragility of the 003 Firewire interface I'm still paranoid about hot plugging any Firewire interface and it breaking, I'd avoid doing that, maybe reboot the computer instead. Are you leaving Pro Tools open overnight? If so don't do that. As mentioned, the most obvious, and very common problem that will cause things like this is just computer sleeping. (but that often needs the computer to be rebooted to clear, your unplugging/plugging may be a different issue. You have to carefully do *every* step in the optimization guide for your OS and Pro Tools version. Do every last thing, however inconvenient. And as already mentioned disable screen saver/sleep, disable AV (better unisntall it an never install any again). Check there is nothing starting up overnight, like backups or software updates, AV update downloads, unisntall all the crapware like that on your system etc. Still stuck. Grab a spare drive, do a clean install of Windows on that. Install the FW drivers, install absolutely nothing else, not updates, no apps, nothing and leave overnight to see if this problem happens again. Last edited by Darryl Ramm; 09-30-2015 at 11:06 PM. |
S5MC disconnecting from PT | Steven1145 | System 5 | 5 | 08-19-2014 02:12 PM |
MBOX PRO 3rd Generation Keep disconnecting: a solution | Intini | FireWire & USB Audio Interfaces (Mac) | 9 | 01-10-2014 10:02 AM |
noise/clicking leads to Mbox disconnecting (LE 8.0.5) | kagagee | macOS | 10 | 04-29-2013 04:00 PM |
Does disconnecting the Mbox-2 USB from its port every night damage it? | JamMasterMax | General Discussion | 11 | 06-02-2010 12:39 PM |
Direct Connect keeps DisConnecting! | Bryan | Pro Tools TDM Systems (Mac) | 3 | 08-03-2001 07:52 PM |
