Old 07-05-2011, 08:12 PM
Solow1nonly Solow1nonly is offline
Default Problem detected with audio clock. Check that your clock source and sample rate are c
I have PT 8.0.3cs running on Windows 7 Ultimate. I have not been able to record or play any wavs via Protools, I keep receiving the error saying, "Problem detected with audio clock. Check that your clock source and sample rate are correct". What could be the issue, I am using an M-Box 2 mini, when I plugged in an older Mbox on the same system, I no longer receive this error????????
Old 07-05-2011, 08:22 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Problem detected with audio clock. Check that your clock source and sample rate a
Firstly you need to have version 8.04 or 8.05 to be compatible with Win7.
http://avid.custkb.com/avid/app/self...p?DocId=393667
Windows 7
The following versions of Pro Tools software are officially supported with Windows 7 Home Premium, Professional, or Ultimate (32 or 64-bit)
Pro Tools 9.0, 9.0.1, and 9.0.2
Pro Tools HD 8.5 (HD Native)
Pro Tools LE 8.0.4 and 8.0.5
Pro Tools M-Powered 8.0.4 and 8.0.5
Quote taken from Here;
http://avid.custkb.com/avid/app/self...p?DocId=353265
Make sure you have latest drivers installed
http://avid.custkb.com/avid/app/self...p?DocId=379411
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 07-05-2011, 08:34 PM
Thanks zedhead, Im dl the updates now and will try to get it up and running. It was puzzling when I plugged in an older mbox mini that I no longer received the error. I was able to play wavs back and record without that error.
Old 07-06-2011, 08:13 PM
Once I DL THE 8.0.4 update I no longer received this problem, thank you!
Old 07-06-2011, 08:22 PM
zedhed's Avatar
A happy ending..Yay
HD 96I/O
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 08:42 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
