Old 11-15-2012, 02:56 PM
shotgunndunn shotgunndunn is offline
Default Bypass all or a selected range of plugins...
Is there a quick way to bypass all or selected (opt + shift + click on...) plugins?
Old 11-15-2012, 03:08 PM
Stig Eliassen's Avatar
Default Re: Bypass all or a selected range of plugins...
Shift+Option+Command+click to toggle bypass on selected tracks. Leave out Shift for same command, but to all tracks.
Old 11-15-2012, 03:16 PM
Default
Thanx!!! Will this only bypass the plugins in say insert A if that is the actual plugin that I click on? Or will it bypass all inserts in a selected tracks?
Thanx!!!
Old 11-15-2012, 03:20 PM
Originally Posted by shotgunndunn View Post
Thanx!!! Will this only bypass the plugins in say insert A if that is the actual plugin that I click on? Yes Or will it bypass all inserts in a selected tracks? No
Thanx!!!
Unless there's been a change, you need a console to bypass all plugins at once on a given track.
Old 11-29-2012, 09:40 AM
Default
Thanx man!!! Is there a quick way to remove all plugins on selected tracks? I'm asking because I've been toying with plugins while still in the recording phase. I'd like to try starting the final mix from scratch. I'll save a version under a new name like... XYZ-no plugins so I don't lose the entire old I'd in case there are some really good aspects of the mix I'd like to bring over.
Old 11-30-2012, 01:10 PM
Default
Shift+Alt+click on insert, and select no insert.
Plugins & Memory ~ BYPASS Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-04-2012 07:31 AM
bypass plugins via midi in pro tools 8? earthcorp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2010 03:31 PM
Bypass all plugins Assi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-04-2008 05:06 AM
Bypass plugins on a track GoldPhazer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2008 11:21 AM
How to hard bypass plugins in XP? lifer Pro Tools TDM Systems (Win) 4 02-07-2006 03:44 PM
