Re: -9171 and -9172 errors Pro Tools 11 | HD
Oh, also, I use disk caching in PT. I'm going to experiment with turning that on and off and see if that has any effect.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
http://duc.avid.com/showthread.php?t=356284
I replaced 5,1 Mac Pro with latest iMac i7. The errors are gone and it's much more stable.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
The errors you're getting have nothing to do with the speed of your hard drive. They have to do with the HDX hardware. Is a known and chronic problem with HDX cards if you try to run at a buffer less than 512. The workaround solution is to go into the playback engine and select ignore errors. If you doubt this information try running ProTools on the same computer off of the built-in output. The problems go away… :-(
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
#16
#17
Jacek, I'm assuming you're using a Sonnet or similar TB to full length PCIe box for your native card?
#18
I get these errors on a 5,1 Mac Pro tools 11 HD running native no hardware attached. Some days it seems better than others. Drives me nuts.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
#19
No matter what buffer or checkbox is checked....
#20
Brian, try eliminating plug-ins to see if they are causing your problem. Four instance, the Sansamp plug-in is a known offender. Try running with just a basic stock avid plug-ins and go from there.
-9171 and -9172 errors with Pro Tools HD 10.3 on HDX | Boe Larsen | Pro Tools HDX & HD Native Systems (Mac) | 519 | 03-08-2017 10:11 PM |
Still getting -9171 and -9172 errors and confused about this 'upgrade' | ArKay99 | Pro Tools 11 | 0 | 12-23-2014 12:23 PM |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
