Old 10-05-2012, 07:35 PM
2crows 2crows is offline
Default protools and solid state HD
hello, i have had a hard failure and need to replace it, i was wondering if anyone knows of any problems w/ solid state hard drives and protools.
thanks for your input.
Old 10-06-2012, 08:32 AM
Kasper Kasper is offline
Default Re: protools and solid state HD
I've been running solid state for my session drives for over a year with no issues, my system drive for about 4 months.
Fast and smooth. I never want to buy a spinning, hot hunk of metal again.
Only downside, price and size, but falling rapidly.
You'll need some adapter sleds if you're on a Mac Pro.
Also, SSD is probably not sanctioned by Digi.
kasper
Old 10-06-2012, 10:30 AM
thanks Kasper,
this is the second HD meltdown in a year,they were 10,000 rpm
raptors (7 years old) must have been a bad batch because they are highly rated these days.
Old 10-06-2012, 10:39 AM
Emcha_audio's Avatar
Be careful with using an SSD for your session (audio) data. They are getting better, but the write/re-write is still an issue in the long run.
Manny.
Wave-T.com
Old 10-06-2012, 11:22 AM
Originally Posted by 2crows View Post
thanks Kasper,
Well, 7 years is a long time for any HD. I've had some last much longer (Raptors included) but I don't really trust them after 5 years.
For mass storage I like the WD RE4. The last 2 I bought are faster than my last gen Raptor.
But I would like to eventually go all SSD. The lack of noise and heat inside the Mac is great, and I can't help but think it will prolong the life of the other components too.
kasper
Old 10-06-2012, 12:32 PM
u r right 7 years is a long life, i think that they are only rated for 5,
do you have any suggestions which ssd to purchase .
i am going to research, i have PT on my laptop, so i am not dead in the water.
Old 10-07-2012, 02:56 PM
do you have any suggestions which ssd to purchase ...
I have used Sandisk Extreme, and Intel 320 series.
Not a hint of trouble with either, so far. (but I still run regular backups)
I've heard good things about Crucial as well.
Check Amazon or NewEgg, both usually have good prices.
kasper
Old 10-07-2012, 03:38 PM
If your going for audio drives w ssd's, I would only use slc drives, not mlc drives. They cost more but less chance for issues.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 10-08-2012, 07:58 AM
In theory, yes, but not really an issue with current SSDs.
The cost of SLC is not worth it (IMHO) It's only for failsafe or military apps, not a consumer product.
Virtually any SSD will be much more reliabale than traditional hard drives.
kasper
Old 10-08-2012, 09:04 AM
i chatted w/ dell, they have my specs on file they recommended a Kingston 240 w/ the bundle ( brackets,adapter, install disk ect.) they wanted $250.00 +-
i found the newer model on amazon for $40.00 less even after shipping.
i will post my results after the install, might help someone.
thanks for everyone's input.
How About Solid State? Sradio Storage Subsystems 43 04-04-2013 03:40 PM
Fs: solid State Logic - ssl Delta link Hd protools to madi interface rainerpuschner Buy & Sell 0 07-11-2012 11:28 AM
Has anyone tried the Solid State HDs? Julia B Pro Tools M-Powered (Win) 6 04-28-2010 06:28 PM
Solid State HD's daveparker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-06-2008 03:41 PM
ProTools and Solid State Logic Alliance??? scoobdaproduca Pro Tools TDM Systems (Mac) 13 01-02-2003 07:47 AM
