Old 06-10-2015, 03:23 AM
Biosphere Biosphere is offline
Default ERXP "SystemId Entered does not match the SystemId on record for this Serial"
Hello,
I recently purchased a used Eleven Rack, and the expansion pack yesterday.
However, when trying to activate using the updater I get the error message listed in the title. This is a Windows 8.1 system (which comes with IE 10 by default).
I have entered every possible variation (checking for white spaces/changing charger etc) of serial and system is from the order confirmation e-mail I received after buying expansion, but no luck.
I have contacted support, but they're only sending me irrelevant KB articles.
I believe (and the error message pretty much states this) that the previous owner regged the unit, and that activation fails due to this.
FW version is 1.0.1.
Can anyone help?
http://protools.ideascale.com/a/dtd/178509-3779
Old 06-10-2015, 04:47 AM
winkelement winkelement is offline
Default Re: "SystemId Entered does not match the SystemId on record for this Serial"
The seller and you should complete transfer of ownership i guess.
http://avid.force.com/pkb/articles/faq/en363631
MacBook Pro C2D 8GB RAM
OS X 10.10.3
PT 12 & 10.3.10
Avid Fast Track Solo
Old 06-10-2015, 10:27 AM
Benoni's Avatar
Benoni Benoni is offline
Doubt it's going to work on Windows 8, there is a problem with IE9,10, and 11 with the updater.
Do you have the Eleven Rack drivers installed?
Do you have access to a Windows 7 or Windows XP PC? It's pretty embarrassing that they haven't fixed this in over 3 years since I first brought it to their attention before the ERXP was even released.
More than likely you will need to get to a compatible PC and have them reset the Serial.
Question....
Did you buy the 11R and ERXP from the same person? Is this a business or individual?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-12-2015, 04:23 AM
Initially there was a "mismatch" between serial and system id, according to support. Dunno if this was due to registration by previous owner or not.
Anyhoo, after that still no joy even with complete removal of all things IE from both Windows 8 and Windows 7 computer.
I finally had to dig out an old XP laptop from the attic. It sort of worked, apart from spending two hours figuring out that the Eleven had to be dis-/reconnected mid upgrade for the DFU driver to be installed (no mention of this anywhere).
Being a coder myself, I've seen my share of hilarious code, but this must be one of the crappiest pieces of software I've come across.
Old 06-12-2015, 06:58 AM
Benoni's Avatar
It is. It's the WORST protection scheme I've ever seen. I've kindly suggested that they never, EVER, use it again.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-12-2015, 10:43 AM
Veiko Veiko is offline
I think something might possibly be broken at Avid's end.
I had the same issue, and they had to give me 3 new serial keys before it would activate.
Old 06-25-2015, 10:53 AM
wavegem wavegem is offline
Hey i just got the expansion pack too and my serial and id are not matching i copied pasted from the products download page. any help would be appreciated
Old 06-25-2015, 01:33 PM
Benoni's Avatar
Mac or PC?
What specific error are you getting?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-26-2015, 10:41 AM
Originally Posted by Benoni View Post
Mac or PC?
system id does not match the system id on record for this serial number..
i copied and pasted multiple times. the numbers are what they gave me
Old 06-26-2015, 01:20 PM
Benoni's Avatar
Ok. Just wanted to make sure it wasn't this error?
Eleven Rack Expansion Pack Firmware 2.01 Update fails on Mac OS X with error: License Activation failed. Please contact an Avid representative for further assistance.
http://avid.force.com/pkb/articles/e...ssage/en422359
If the numbers don't match you need to contact Avid so they can get you some new numbers.
Is this Mac or PC? I ask because there are issues with Internet Explorer 8/9/10/11 and the ERXP installer.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Expansion Pack - SystemID? jimst57 Eleven Rack 6 03-22-2011 01:12 PM
*The serial number you entered has already been registered.????? ElQueso Pro Tools M-Powered (Win) 3 05-14-2010 09:35 AM
The serial number you entered has already been registered.?? joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2008 07:08 AM
