Old 08-13-2000, 04:41 AM
David Wright David Wright is offline
Default 16-bit v 24-bit Optimized Mixer
I'm using the 16-bit optimized mixer on my NuBus PTIII sustem, PT4.1.1. Since I can only handle 16-bit disk files that seems logical. I use a number of plug-ins (mostly Waves) and of course they operate at 24-bit resolution. I've not seen any comprehensive explanation of what exactly the difference is between the 16-bit and 24-bit optimized mixers, and I'm wondering if there would be any advantage in my using the 24-bit?
Old 08-16-2000, 11:09 AM
Kris Kris is offline
Default Re: 16-bit v 24-bit Optimized Mixer
From what I understand, the 24 bit mixer has more headroom, other than that you don't lose any sound quality by using the 16 bit mixer. I use the 24 bit mixer unless I run out of DSP horsepower, then I'll switch to the 16 bit mixer which usually frees up a few chips on the DSP farm.
My studio: http://www.logcabinmusic.com
Clipping in 24-bit Optimized Mixer bigfrog Pro Tools TDM Systems (Mac) 2 09-17-2003 12:33 AM
24-bit Optimized Mixer version 5.1.1x330 Loopy C Pro Tools TDM Systems (Mac) 14 05-23-2003 03:00 PM
16 bit optimized mixer in HD? michael c Pro Tools TDM Systems (Mac) 12 06-28-2002 02:28 AM
24-bit Optimized Mixer cs3? Mauro371 Pro Tools TDM Systems (Mac) 1 06-01-2001 08:50 AM
Detailed information on 24 bit optimized mixer blairl Tips & Tricks 7 03-24-2001 12:23 AM
