Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-09-2024, 09:56 AM
Kasper Kasper is offline
Default Re: mac OS Ventura driver for yamaha 01v96i
Assuming he's on Apple Siiicone it's not a waste of time, it's mandatory.
Default security settings need to be changed to allow installation.
Follow the link, it's quite clear.
"By default, your Mac uses the highest level of security, called Full Security. Before a legacy system extension (also known as a kernel extension or kext) can be installed on a Mac computer with Apple silicon, the security policy must be changed to Reduced Security...."
The same is also stated by Steinberg/Yamaha.
https://download.yamaha.com/files/tcm:39-1588312
kasper
Old 02-10-2024, 04:26 AM
OARecords OARecords is offline
i fixed it with Yamaha Steinberg USB Driver Installation Guide
for apple silicon:
1. Shut down your Mac.
2. Press and hold the power button until you see ""Loading startup options …"".
Your Mac will boot into Recovery mode.
3. Click Options (gear icon), then click Continue.
4. In macOS Recovery, select the volume you want to install the driver on and
click Next.
5. In macOS Recovery, choose your account and click Next.
Enter the password and click Continue.
6. In the top menu go to Utilities -> Startup Security Utility.
7. Select the system where you want to install the Yamaha Steinberg USB Driver.
If the disk is encrypted with FileVault, click Unlock, enter the password, and
then click Unlock."
8. Click Security Policy, choose Reduced Security and check the option to allow
user management of kernel extensions from identified developers.
9. Click OK.
Enter the password for your account and click OK.
10. Restart your Mac from Apple menu.
Now pro tools see my mixer 01v96i and everything work!
Thank you all for the support!
Old 02-10-2024, 08:48 AM
Excellent, happy to help, that's what the DUC is all about.
Cheers,
kasper
Old 02-10-2024, 11:00 AM
basslik's Avatar
basslik basslik is offline
Originally Posted by Kasper View Post
You may want to give this a look RE: security settings on Apple Silicon.
https://support.apple.com/guide/mac-.../13.0/mac/13.0
kasper
Great info kasper.
Haven't used my ancient dinosaur ASR10, and probably would never see the daylight of the rubber chicken software in this day and age. Although midi seems viable. Nonetheless that good good info down the road.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Can’t install Thunderbolt Driver for DADMan on Mac Ventura. TheoNogueira Pro Tools | MTRX & MTRX Studio 7 11-27-2023 01:50 PM
Yamaha USB midi driver provlem tripstation Pro Tools 12 4 12-17-2019 04:12 PM
Yamaha 01v96i and PT9 kjxtreme Windows 4 01-03-2016 12:04 PM
Warning about malicious Yamaha USB MIDI driver Mediterraneo ProControl, Control|24, Command|8 0 06-27-2007 11:33 PM
Yamaha NS10 driver size? Greene Pro Tools TDM Systems (Mac) 1 07-24-2006 02:17 AM
