Old 01-17-2023, 03:21 AM
Zergei72 Zergei72 is offline
Default DIGI 002 Rack / Behringer VIRTUALIZER 3D FX2000
Trying to set up the routing for my out-of-box fx processor .
I'd like to record a stereo signal from the processor .
I have a condenser mic going to MIC 1 in on my DIGI 002 .
outputs 5 & 6 from DIGI 002 go to the ins on the Behringer and from the Behringer outs the routing goes to ins 3 & 4 on the DIGI 002
I get signal on the mic channel (1) and I can see the meters moving on the Behringer, but how to proceed from this point .
I'm awfully lost .
HELP ASAP,
- Z -
Old 01-17-2023, 11:11 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: DIGI 002 Rack / Behringer VIRTUALIZER 3D FX2000
IIRC, the ins and outs must match. So 5&6 out of the 002 and 5&6 into the 002.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-17-2023, 11:14 AM
Okay, this is just my 2 cents, but...
#1-what is the Behringer doing that you can't reproduce with a plugin?
#2-are you trying to use the Behringer as an insert(so it all stays within your audio track)? If yes, then you must setup insert paths in the Setup>IO window, and inserts must use the same numeric IO(this means if you use outputs 5&6 to feed the Behringer, then it must come back in on inputs 5&6).
#3-if nothing above helps, describe in complete detail(even down to the exact cables and connections)
Digidesign DIGI-002 / Behringer Virtualizer 3D FX2000 - Routing Zergei72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2021 03:37 PM
Digi 002 Rack & Behringer ADA8000 amcreative 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-30-2010 03:15 PM
Behringer MX802A and 002 rack? Kryst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-05-2010 02:33 PM
Is bpm sync possible with Behringer Virtualizer pro? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2008 10:51 AM
virtualizer clipping, pro tools headroom ok? neonknight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-26-2004 02:03 PM
