Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-13-2020, 02:54 PM
dg27's Avatar
dg27 dg27 is offline
Default Orange peak meters
I just moved to 2020.3 from 12.8.3. Either my previous preferences were different and I that's why I didn't see them, or the orange peak meters are a new feature. (And I use Waves CLA-76 a lot and that never had a meter light on the insert.)
I've read through the metering section of the reference manual, searched the posts here, and Googled, but I'm unclear as to what I'm actually looking at. I think what throws me is that it comes from the top. Is the lower part (how far down it goes) where it's peaking?
For the record, I use Pro Tools Classic metering, Track and Master Meter Types Linked. Peak Hold is set for 3 seconds and Clip Indication is set for infinite.
I apologize if this is regarded as an an inane question.
dg
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 04-13-2020, 02:58 PM
priorytools priorytools is offline
Default Re: Orange peak meters
dg
Can you post a screenshot?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 04-13-2020, 03:23 PM
dg27's Avatar
Thanks for your reply, priorytools.
Google Photos wouldn't let me upload the mix window screenshot (?), but here's the edit window:
Old 04-15-2020, 01:35 PM
dg27's Avatar
I looked into this further and what I was referring are actually the gain reduction meters.
Old 04-15-2020, 03:03 PM
I figured as much.
Your pic link doesn’t work.
You can configure those gain reduction meters in preferences.
Old 04-16-2020, 04:00 AM
Drew Mazurek's Avatar
Orange peaks mean it would peak/clip if it were sent to the 24 bit world, but it's not actually because the PT mixer is 32bit float. A red peak means the audio is assigned to a 24 bit output and therefore IS peaking/clipping.
www.drewmazurek.com
Old 04-16-2020, 05:37 AM
wafare wafare is offline
Avid changed peak over 0 dBFS meters a while ago from red to orange for all track types except the Master Fader, which still shows red. When in record mode, it will still show red for clip indication. The reasoning is as long as you're within the mix engine, which has virtually unlimited headroom, you're not actually clipping within the mix engine. However, at the Master Fader, it is actually indicating clipping in red because it is leaving the mix engine and on its way to your speakers where you'll actually hear it.
2013 2.7 Ghz 12-Core Mac Pro
64 GB Ram
1 TB SSD
OS X 10.14.6
Lynx Hilo TB D/A
Prism Lyra A/D
Apogee Symphony MKII 2X6 SE
Pro Tools Ultimate 2019.12
MASELEC MTC-1x
MASELEC MLA-2
MASELEC MEA-2
MASELEC MPL-2
MASELEC MLA-4
MANLEY (Mastering) SLAM!
MANLEY MASSIVE PASSIVE (Mastering)
X2 Rupert Neve 5059
WAVES L2 Ultra Maximizer
Artist Control
X2 Artist Mix
Old 04-16-2020, 07:24 AM
dg27's Avatar
I figured as much.
Thanks.
I'm trying to decide which setting is more useful: seeing how much a comp is reducing the gain or going with the sum.
Orange Line on Meters Tgrgs Windows 5 01-02-2017 03:11 AM
Meters won't peak while recording...EVER!!?!?? illution1 Pro Tools 10 39 04-29-2014 10:21 AM
Meters--Peak or PPM? danika Pro Tools M-Powered (Win) 0 10-15-2005 12:55 PM
Outboard VU/Peak meters ... CCash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-04-2002 04:12 AM
peak meters dellamattia Digidesign Hardware & Software 2 03-27-2001 01:35 AM
