Old 02-14-2020, 12:51 PM
Sara_posada Sara_posada is offline
Default Video Engine Unrecoverable Error
I subscribed to Pro Tools (2019.12) precisely to use it with video and ever since I installed it the Video Engine has never worked. It says there's an "unrecoverable error". I have uninstalled it and installed it again, I tried installing the 2019.10 version and I have done everything the duc says that has solved the problem with past versions of Pro Tools but nothing seems to solve this problem.
HELP PLEASE! I have a Macbook Pro 2011 on High Sierra.
Old 02-14-2020, 02:19 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Video Engine Unrecoverable Error
Hi, welcome to the community.
Could you please be more precise with the error message. There must be a code to begin with...
Janne
Old 02-14-2020, 03:01 PM
Hi, thanks for your quick response,
every time I try to open a session that has video in it a window pops up saying textually "The Video Engine had an unrecoverable error and will now reinitialize", if I press ok, another window appears saying "Waiting for the Video Engine to Launch...". It fails every time leading to the same messages appearing over and over again.
Old 02-17-2020, 12:03 PM
made made is offline
this happens as far as I know on slow macs very often.
-Try using a codec like DNxHD or ProRes
-Try a seperate SSD for video playback
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 02-17-2020, 12:07 PM
JFreak's Avatar
Yep, fastest 2011 MBP is not very fast by today's standards. Also, how much memory? Current PT requires at leat 16B which is maximum a 2011 MBP can take. If OP has 8GB that is something that may cause problems with or without video.
Janne
Old 02-17-2020, 02:50 PM
gives's Avatar
gives gives is offline
Hi, It actually happened to me the other day setting up my Surround room and while testing an old PT session from 2007 which was updated, I had to delete a DVCPro QT that was giving me problems to get this to go away.. I got the same message, which have never happened before. I also have a very fast Mac with Lot's of Ram 64GB, so that's my take for the person wondering. Hope that helps. I have not used DV/DVCPro format in years, so I converted the file and the problem went away.
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 03-31-2020, 06:39 PM
FIXED
This issue was only fixed by updating to the 2020.3 version of pro tools which is now available
Thank u all for your help and good will
Old 03-31-2020, 07:43 PM
sw rec sw rec is offline
Glad that did the trick for you...it didn’t change ANYTHING on my Win 10 rig. Everything else works great, but attempting to import ANY video gives the spinning icon of death right before it locks Pro Tools, and you have to force-quit in task manager. I’ve tried every format imaginable, but get the same result regardless. Only option I have is to open pt 10.3 and import a .mov file.
Old 08-03-2020, 07:50 AM
blindspot blindspot is offline
The following worked for me:
Go to /Library/Application Support/Avid/AVX2_Plug-ins and empty the contents of this folder if any.
Go to /Users/Shared/AVidVideoEngine and delete this folder.
Old 03-02-2022, 04:48 AM
ulriklyhne ulriklyhne is offline
Thanks @blindspot! Works like a charm.
If you have a Black Magic videocard installed, you should leave the file "OpenIO_Blackmagic.acf" in the path: /Library/Application Support/Avid/AVX2_Plug-ins/
That way the card is adressable by the video Engine.
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Video Engine Error aptmusic9 Pro Tools 11 7 03-10-2017 01:55 PM
The Video Engine had an unrecoverable error HDXSound Pro Tools 11 14 02-21-2017 11:35 AM
Video Engine Error? bifbangpow Pro Tools 12 1 09-29-2016 07:02 PM
Video engine still sucks (repeated unrecoverable errors) HDXSound Pro Tools 12 13 04-03-2016 06:41 PM
