Old 06-22-2019, 12:26 AM
silky38 silky38 is offline
Default Isue when dragging clip from clip bin to edit window
Hi
A friend of mine prepared some sessions for me on his system and sent them to me recently. he uses a Mac and Pro Tools HD. I use a PC and have standard Pro tools. When I try to move a clip in the edit widow the clip appears about one and a half tracks down and out of alignment with the clip I'm dragging. See the attached photo.
Also when I drag a clip from the clip bin the same things happens again. See the attached photo.
This is making it very difficult to edit as I can't line clips up properly.
Thanks.
Old 06-22-2019, 01:03 AM
Default Re: Isue when dragging clip from clip bin to edit window
Found out the issue myself. Turn off clip transparency.
Old 06-22-2019, 06:20 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Originally Posted by silky38 View Post
Hi
Thanks.
This usually only happens on Win7 since the PT stopped being qualified for it. And, as you found turning of transparency remedies it. I would be surprised if it was happening on WIN10 but your post doesn't specify. The only reason i'm replying is to add the version info for any one else.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 11-04-2023, 08:34 AM
Songster Songster is offline
Mine is doing this too and I'm on Win10. Where do you turn on/off Clip Transparency? This was working a few days ago and just stopped working
show clip name in edit window browniespeaks Windows 2 05-11-2020 04:05 PM
Issue dropping more than one clip into the Edit Window with Clip Transparency ON arb232 Pro Tools 12 0 02-10-2016 06:01 PM
Dragging Clips from Clip window - ALWAYS Vertical sort!? davedotpez Post - Surround - Video 2 05-20-2015 07:24 PM
Edit window moves on selecting clip tooold Pro Tools 11 3 12-02-2014 12:13 PM
Clip indicators in edit window P_J Pro Tools 11 4 10-17-2013 05:40 PM
