Old 09-11-2015, 10:39 PM
paldry paldry is offline
Default Can't see Addictive Drums
I've just installed Addictive Drums 2 on my Mac Book Pro. I'm running PT 9 and cannot see AD2 in the instruments through inserts. Any advice/suggestions would be welcome. Thank You
Old 09-11-2015, 10:49 PM
Top Jimmy's Avatar
Default Re: Can't see Addictive Drums
Trash prefs and databases so PT has to do a full rescan of the plugins folder.
http://www.sweetwater.com/sweetcare/...s-preferences/
James Cadwallader
Old 09-11-2015, 11:08 PM
Southsidemusic's Avatar
Hey
AD2 doesn't seem to work on PT9 anymore
If you scroll down on This webpage it says aax32/64 but no rtas so you have to upgrade your PT9 if you wanna use AD2
http://www.xlnaudio.com/knowledge-base/#requirements
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-12-2015, 09:09 AM
Or try to get AD1, which is RTAS
Old 09-14-2015, 03:24 AM
Thanks Jimmy,Thanks for you help. I checked the link out but I'm having trouble finding the preferences folder they are referring to:
Pro Tools 10 and below on Mac
Go to Macintosh HD\Library\Application Support\Digidesign and delete the Databases folder.
Go to you User folder and select Library (on Mac OS X 10.7 and up, you need to select the Go menu from the Finder task bar while holding the Option key to access the User\Library folder).
Go to the Preferences folder and delete the following items:
com.digidesign.ProTools.plist
DAE Prefs
DigiSetup.OSX
Pro Tools Prefs
Empty your trash.
Old 09-15-2015, 05:06 AM
Thanks Jimmy I followed the instructions as per your link but to know avail :) I'm running PT 9 and trying to see Addictive drums 2... Any other suggestions would be appreciated
Old 09-15-2015, 07:53 AM
Ben Jenssen's Avatar
Like Dave and Christopher said, AD2 is AXX format only, and PT9 must have RTAS. AD1 is RTAS.
So you must either upgrade to PT10 (takes 32bit AAX), or try and find a v1 of AD (RTAS).
Be aware that Addictive Drums v.1 and 2 are incompatible, v2 wont be able to open a session with AD1 inserted on a track.
[IMG] code is Off
Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem) Don Bravo General Discussion 5 07-04-2014 11:49 PM
Addictive Drums Tonesy Virtual Instruments 4 07-02-2014 10:04 AM
Addictive Drums RTAS instrument plugin much softer when drums are "individualized" jglunt2112 RTAS & TDM Plug-ins 7 12-05-2013 06:54 PM
Addictive Drums paradiddlebob Pro Tools SE and Essential (Mac) 3 02-03-2012 08:58 PM
addictive drums, drums replacement ericlees Tips & Tricks 2 09-28-2010 10:58 PM
