Old 11-22-2014, 11:06 AM
Gneal550 Gneal550 is offline
Default Pro Tools 11.2.1 Automation Bug?!
Has anyone else had an issue with opening a session and the tracks act as if there is automation on them, but there isn't. I've checked for automation points from the beginning to the end of the session and there are none, but the faders will not move from their original levels. I've opened the session on multiple rigs (all Pro Tools 11.2.1 with HD I/Os) and the problem doesn't go away. There only work around so far is to automate the channels to -0Db which is a huge time waster? Any help??
Old 11-22-2014, 01:15 PM
DigiTechSupt's Avatar
Default Re: Pro Tools 11.2.1 Automation Bug?!
Thanks for sending the session file.
Not a bug... you actually have Volume Breakpoints in most of your tracks.
Change the tracks from Waveform to Volume and look at 3|1|000, 5|1|000, 11|1|000, 107|1|000, etc. Your Lead Vocal tracks have even more extensive volume automation.
You can delete all the breakpoints or change the track's AUTO to Off if you don't want those breakpoints controlling your faders.
Regards,
JC
Avid Audio Tech Support
Support FAQ
Automation AppleScripts for Pro Tools (Mac) Oliver M Tips & Tricks 311 12-21-2023 12:02 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
Pro Tools Version 8 pan automation. sstanley Pro Tools TDM Systems (Mac) 0 02-23-2009 10:03 PM
What is the deal with Pro Tools automation??? sethbrand Pro Tools M-Powered (Mac) 4 03-26-2008 06:06 PM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
