Old 07-04-2014, 07:34 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default HD I/O Outputs Hot (+7dbm RMS) Factory
Hi. Have anyone else noticed the HD I/O outputs ship trimmed-hot?
All inputs seem close but so far for me two 16x16 and one 8x8 all set for +7 out.
Fluke 867b RMS AC meter
1KHz set for -18 RMS (Avid Tone Generator)
Curious.
Old 07-04-2014, 08:55 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: HD I/O Outputs Hot (+7dbm RMS) Factory
Luckily you can calibratre the outputs to the voltage of your liking :)
Janne
Old 07-04-2014, 09:22 AM
What dBm measurement resistance setting are you using in the meter? And what load was the outputs actually driving? You really want to calibrate these outputs as described in the manual, not by relying on a meter making power calculations from a voltage measurement.
If the input calibrations look better to you how exactly are you measuring those?
Old 07-04-2014, 11:52 AM
DetroitT's Avatar
Always Outputs first. Using Fluke (Factory calibrated) 687b Meter set to RMS AC 600 ohm load. measure across pin 2 and 3.
Matching to SSL 6K setup for +4db = 0 VU (VU meter console)
Once out are trimmed to 1.228v they match the consoles VU meters. (Done)
I patch HD I/O out to in for input calibration (Cal template with rooms I/O bussing)
24 in x 48 out room 1 and 24 in 32 out room 2.
Cal Sounds great. Just curious when the hardware is spected referencing (-18dbfs headroom = +4db = 0 VU) the come set high from the factory.
Old 07-04-2014, 11:59 AM
Cool. I've just seen accidents where the reference ohms setting is changed in meters like this (like when you lend the meter to somebody...grrr).
Darryl
Old 07-04-2014, 01:06 PM
thierryd thierryd is offline
My HD I/O came as standard above and I put it 2dB higher to cal for -20dBFS = +4dB = 0VU, as I did with the 192 before.
Greetings,
Thierry
http://www.a-sound.com/
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Digi 003 Factory Outputs 1-2 jackmackdaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-22-2011 12:46 PM
Apogee Duet outputs better sounding than Digi002R outputs? Pasz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 02:19 AM
please help on mirroring outputs 1-2 to s/pdif outputs! ournature 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-13-2007 08:52 PM
how to authorise Bomb Factory plugins w/ Factory 001 bundle MGalway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-05-2002 10:34 AM
