Old 02-25-2014, 05:47 AM
cloudchamber cloudchamber is offline
Default Cant open my session or the audio files on same or other PT rig
Hi all ... Have a very urgent matter.
Can´t open a very important session due to the following message:
pro tools cannot open this session because it was created on an older version of pro tools.
I have read all old post but nothing works..
On a new firewire disk with 2 partitions I created a session on my HD3 PT10.03.5 -recorded voiceover for 2 hour, played back the files and saved and closed the session (I pressed save many times during the recordings too). Created another session on an internal disk, worked with that for an hour -and closed to open the first session again.
-Then i got the message: pro tools cannot open this session because it was created on an older version of pro tools.
Tried on other Mac OS 10.6.8 ProTools rigs
-PT 10.3.5 HD 3 Blue Interface
-PT 10.3.7 Full production Toolkit with DIGI 002 AND
-PT 10.3.0 HD 2 Build in Audio
and got the same message: pro tools cannot open this session because it was created on an older version of pro tools.
-Then I tried to import into a new clean session
-Then I tried to import and audio file a new clean session.
When the audio file was selected the ADD button stayed "grayed out"
Finally I tried to open a wav in other audio programs no luck :-(
Quicktime says: (OSStatus error -208)
BWavReader says: (This doesn´t seem to be a Wav file)
In the session folder I see the files, the size count are approx. as they should be.
Please give me any info or tips ???
Old 02-25-2014, 05:52 AM
Default Re: Cant open my session or the audio files on same or other PT rig
I forgot to say I deleted PT prefs and that the other session created on the rig opens fine
Can Pc Session files open on a mac running 7.0? gobzilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-23-2007 05:38 PM
Can Pc Session files open on a mac running 7.0? gobzilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-22-2007 08:58 PM
can't open files session files .....plz help... syntax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-19-2004 07:09 AM
Open Files from TDM session in LE baugh05 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-15-2002 08:18 AM
5.1.1 session files open in 5.0.1 with no tracks?? fshrking Pro Tools TDM Systems (Mac) 3 01-26-2002 11:17 AM
