Old 04-17-2012, 07:21 PM
11R Newbie 11R Newbie is offline
Default Eleven Rack and Eleven Rack control window not matching
Hi guys,
I'm sure this is a very newbie question but I'm a newbie so here it goes...my Eleven Rack isn't matching the Pro Tools Eleven Rack control window. For example, when I'm using a rig with the Mesa Dual Rec sim and 4x12 V30 cabinet sim, the control window shows the SLO sim and 4x10 cabinet sim. There are other amp sims that don't match either. Some do and some don't.
I've got Pro Tools 10, the Eleven Rack I bought (new) came loaded with the expansion pack and I didn't encounter any issues when installing either.
Any suggestions as to how to get everything to match?
Thanks
Old 04-17-2012, 08:58 PM
Default Re: Eleven Rack and Eleven Rack control window not matching
You need to install the expansion pack update on top of your Pro Tools install. See here http://avid.force.com/pkb/articles/e...oting/en425171
Old 04-18-2012, 07:02 AM
Benoni's Avatar
Benoni Benoni is offline
yep, just install the first section of the ERXP installer as mentioned above.
If you want/need more detailed instructions [with video]
check here:
http://elevenrackusers.blogspot.com/...howing-in.html
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-18-2012, 06:07 PM
Thanks, problem solved.
No Eleven Rack Control Window With Pro Tools 11 turbolx5oh Eleven Rack 15 12-08-2014 03:28 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack control window Charvelman Eleven Rack 7 07-21-2011 01:14 PM
Eleven Rack control window? microstudio Eleven Rack 6 02-25-2011 01:04 AM
Where is the eleven rack control window? Hotcrazyfruit Eleven Rack 32 10-22-2010 03:21 PM
