#31
Re: HEAT, NEVE 8048 Listening Challenge
I thought they were clear that this was a summing comparison and NOT a mix ITB vs OTB. Obviously with a Neve console you'd need to rely that the UAD NEVE modeling was on point.
In my experience mixing with the UAD NEVE plugs (1073, 1081) coupled with HEAT has made my clients extremely happy!
http://www.youtube.com/c/wizprodux |
#32
yeah, that's what I mean. In the old test they did the complete mix in vs. out the box. I like the new test better, but I would have preferred it the ABX way...
#33
If you picked HEAT as the best sounding, and therefore chose NEVE cuz of your bias to expect NEVE to be better, all that means is that you preferred HEAT the most, not NEVE. Am I missing something in what you said?
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
#34
Exactly, it seems as though: 1) people don't understand why a double blind us the most accurate test and, 2) don't understand that their own bias will effect the outcome if they are allowed to know which source is which. Anyone who doesn't think that their mind can talk their ears into hearing what they want is naive at the very least.
#35
2) The main reason the test is flawed is because it REQUIRES us to be be biased in order to even make the selection. We need to pick the best sounding mix then assign it to what choice we expect to be the best sounding. So If I assume the NEVE to be the best I need to pick NEVE when I hear the best one. Obviously this doesnt work because if HEAT is actually the best...I will get most of the answers wrong. The bigger point is the mistaken assumption that since so many people are getting so many wrong that they all must sound the same. This couldnt be further from the truth since I would assume that most of us agree they all sound very different. |
#36
I'm interested in the differences between the Neve and HEAT - as everyone is - but the results are being falsely interpreted. |
#37
It seems you understood me, did you ever do this test? If you did, you should know, you don't know which is which before you submit the answer, so I guessed the ones I like most is by HEAT, but I'm totally wrong, then I made a oppsite choice, guess the ones I like most is by Neve, and most of the answers are right, so I can tell, to my ear, the best result is from NEVE but not HEAT. Understand? |
#38
We are attempting to remove any bias or 'tipping of the scales' by not telling you what is the Neve, Pro Tools Only or PT HEAT mix. That way you are not biased. You are listening with fresh ears, and if they sound different to you, you can attribute which mix you think is which format. I personally feel they are pretty darned close. IMHO, this test is not about picking which one is the best sounding mix. That question, about which you prefer (and the question about how hard was it) does not weigh in on the scoring results. You are only judged on your ability to identify correctly which mix is summed/done on which format. Most people have answered that the test was very hard to hear a difference, which is in contradiction to your comment that they sound very different. I get that there are multiple ways to do this type of testing/experiment and we spent a lot of time, effort and dollars to make something we felt would be fair and eye opening at the same time. Sorry this doesn't work for you... Maybe we can do another version early next year. Thanks for checking it out though...
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
#39
Post Script :
780 People have taken the test as of this morning. 78% said they were not sure how they did, that it was pretty hard. The average correct identification is 30%
#40
If it was important for the test to be done this way what would have made the results more relevant would have been to FIRST play 3 examples and tell us which is which, then ask us to identify the rest of them based on having a reference to what each option sounded like. Or if the idea is to give no bias then just ask us to pick the best sounding etc. But to have to try to attribute what is what based on what we might expect it to sound like would by design produce irrelevant results. Also, the test doesn't even tell us how the Neve mix got back into protools. Different AD converters could also produce very different results. At the very least we should have heard samples of each so we could have some idea of what we were trying to identify. To sum it up (pardon the pun) The reason I took part in this and am taking the time to comment on this is I really would like some real world reactions on how others perceive HEAT vs other options but I don't think this test served that purpose. I do appreciate the time and expense you put into this, but I thought it was important to provide this feedback. |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
HD6 vs HDX2 "ITB" Listening Challenge | Tom Graham | Pro Tools HDX & HD Native Systems (Mac) | 131 | 12-19-2012 03:45 PM |
HD6 vs HDX2 "ITB" Listening Challenge | Tom Graham | Pro Tools TDM Systems (Mac) | 0 | 11-01-2012 08:17 PM |
Heat challenge issue... hmmmm... | velvettone | Pro Tools TDM Systems (Mac) | 10 | 12-06-2010 04:46 PM |
heat vs neve summing test | ericlees | Pro Tools TDM Systems (Mac) | 1 | 10-30-2010 07:14 PM |
