No audio playback on MBox 2 PRO (Windows XP Pro SP2)
I have run many installs/re-installations of Pro Tools LE 8 and CAN NOT for the life of me get any audio playback out of my MBox 2 Pro. Here is my Sandra Report:
SiSoftware Sandra Computer Model : Asus System Product Name Workgroup : STUDIO Host Name : jmartin User : James Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus CG5290 BIOS : American Megatrends Inc. 0502 05/11/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.63GHz (5.26GHz) Chipset Model : Intel Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.63GHz (5.26GHz) Total Memory : 9GB DDR3 Memory Bus Speed : 2x 584MHz (1.17GHz) Memory Module(s) Memory Module : Nanya NT2GC64B8HA0NF-CG 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Nanya NT1GC64B88A0NF-CG 1GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Nanya NT2GC64B8HA0NF-CG 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Nanya NT1GC64B88A0NF-CG 1GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Nanya NT2GC64B8HA0NF-CG 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Memory Module : Nanya NT1GC64B88A0NF-CG 1GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 4-33-10-5) Video System Video Adapter : NVIDIA GeForce GTX 260 (216 SP 1.15GHz, 896MB DDR3 2x1GHz, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GTX 260 (216 SP 1.15GHz, 896MB DDR3 2x1GHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce GTX 260 (216SP 1.24GHz, 895.7MB 2x1GHz, Integrated Graphics) Storage Devices Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 932GB (C:) (E:) ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) : 466GB (D:) HL-DT-ST DVDRAM GH40N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (F:) Logical Storage Devices Pro Tools (D:) : 466GB (NTFS) @ ST3500320AS (500.1GB, SATA300, 3.5", 7200rpm, NCQ) Windows 7 (C:) : 373GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) DATA (E:) : 549GB (NTFS) @ Hitachi HDT721010SLA360 (1TB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) Pro Tools Loops (F:) : 8GB (CDFS) @ HL-DT-ST DVDRAM GH40N (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13h Audio Device : ASUS HD Audio Controller Audio Codec : Analog Devices 989Bh Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS 3403h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance : x86 Anyone know why this is happening?? Any help at all would be great BTW, Pro Tools installed fine, runs fast, loads fast, and levels show on playback but NO AUDIO. I have tried every output on the Mbox...
ASUS CG5290 - Intel Core i7-920 / 2.66 GHz - 9GB DDR3 SDRAM - NVIDIA GeForce GTX 260 - 1TB SATA & 500GB SATA - Windows XP Pro SP2 MBox 2 Pro - Pro Tools LE 8 |
Re: No audio playback on MBox 2 PRO (Windows XP Pro SP2)
If you make a stereo master fader on Analog 1/2, does the level meter show a signal?
Are you trying to listen with earphones or monitors?
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
Yes, playback levels show on all tracks, including the Master. I have tried headphones in every possible jack, pressed all possible buttons, and also tried monitors run from the rear outputs - no sound at all on playback.
The above is all from the Jazz Demo Session that came on one of the DVD's. On my own session, I can not get it to show input levels when armed for recording, so I can not record any of my own audio. I am running stereo 1/4" stright from my Yamaha Motif and can't get any input signal...
Windows 7 & Mbox 2 - Silent Playback? | Marello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-02-2012 03:34 AM |
To use Mbox 2 as playback device in Windows Vista | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-10-2010 05:22 AM |
Playback Windows Vista Sounds thru Mbox?? | creativesounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-18-2008 03:30 PM |
Digi002 as audio playback for windows | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2005 02:48 PM |
Mbox Playback with Windows XP | Ryan_412 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-27-2004 10:01 PM |
