Old 05-02-2009, 10:55 AM
Floydio Floydio is offline
Default Key-Command for dropping automation point?
Hi folks,
Is there a key-command for dropping an automation point??? (Using PT 7.2 Mac OS)
Here's why: editing and mixing 'in the box' with a mouse and always zooming in to the frame that the I-Beam/cursor is on in a specific track so I can see close enough to click the mouse to drop an automation point there.
It would be much more efficient if there was a keystroke to just DROP a point wherever your cursor is. I use markers a lot for scene splits, etc. and would love to just be able to drop a point and move on, so I can make my volume adjusts/automation adjusts quicker.
Thanks.
Old 05-02-2009, 11:52 AM
Drew Mazurek's Avatar
Default Re: Key-Command for dropping automation point?
Command /
www.drewmazurek.com
Old 05-02-2009, 01:27 PM
Exclamation Re: Key-Command for dropping automation point?
BRILLIANT!
Thanks VERY much.
(just have to remember to enable volume automation)
Old 05-02-2009, 10:04 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
"Command(apple) / "is also great for flattening out an area of break points.
Let's say you have a region with random breakpoints all over the place, highlight it and hit the key comb, voila you end up with 2 points at the start and end of region.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 05-03-2009, 05:54 AM
And Command-Shift / used to be Trim enabled parameter until Apple stole it for enabling Help.
You could make a selection, move the fader or parameter and then press Command-Shift / and it would add or subtract the amount you added instead of writing the current position like Command /. Of course it's still available in the menu but we lost the shortcut.
www.drewmazurek.com
Old 05-09-2009, 05:02 PM
theom theom is offline
Is this a HD or should I say TDM only shortcut?
It doesnt seem to work on my native 002R 7.4 LE rig.
I want a key command to flatten a selection with many to two break points.
The / key is the one with the ? mark right? next to the right hand shift key correct?
Thanks
Old 05-09-2009, 08:36 PM
reichman's Avatar
reichman reichman is offline
If you don't have the key command in PTLE, it might be because you need DVTK2 or CPTK. Those toolkits definitely have it, as I use it a hundred times a day in PTLE w/ CPTK.
Old 05-10-2009, 08:26 AM
hmmm.
I have the MPTK. I dont think I have the shortcut.
So, what i have to do is highlight a selection containing the multiple breaks, Hit delete, then with the selection still highlighted use the trimmer.
that creates 2 new breakpoints and a flat line.
1 key command or a hold option while draginging trim tool would be much better for my workflow.
Old 05-11-2009, 03:32 AM
tonwurm's Avatar
tonwurm tonwurm is offline
on my system it still works !
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 05-11-2009, 04:56 AM
tj_davies tj_davies is offline
Thanks
I actually use / on the numeric keypad - try that!
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Four-point automation w/fades? bleen macOS 1 02-22-2014 05:47 PM
Move Automation to Sync Point quoid macOS 2 02-26-2011 10:11 AM
dropping automation break point exactly on grid and location line? crizdee Pro Tools TDM Systems (Mac) 5 02-27-2009 12:03 PM
Automation point resolution Centurion Pro Tools TDM Systems (Mac) 1 01-20-2003 08:58 AM
Automation point moving Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2002 03:46 PM
