Relinking Audio Problems
Hello,
I moved a session stored on a separate drive onto my audio drive for a remix and PT can't relink to the audio. I've tried automatic and manual relink. I've tried to relink to audio files on the external drive and the main audio drive. The audio files are there; PT just can't find them. The problem probably is that the audio was originally recorded to a drive which is offline. I think I dragged sessions to a new drive to copy them over, instead of "Save Session In". So, the audio files are marked with an identifier that refers to the offline hard drive. Still, shouldn't PT be able to relink? I think I've tried everything in the manual and searched the DUC archives for something else to try. I'm running PT 6.9.3 with HD 3 Accel on a Mac Dual 1.25 MDD. Any help will surely be appreciated. Thanks, Chas
http://www.cdbaby.com/cd/chaswilliams |
Re: Relinking Audio Problems
Hope this helps:
1) Open the session in question with the external hard drives connected to your computer. 2) With the session open, open the Project Browser window. 3) Click on the little triangle that allows you to view all the audio files. 4) Scroll to the right so that you can reveal the column marked PATH and sort your audio files by PATH. 5) Select, by clicking on the names of the individual audio files, the files that are not on the drive you'd like them to be on. 6) Using the window pull down menu while your files are highlighted, select COPY & RELINK (or RELINK & COPY - sorry, I'm not at my computer right now). 7) A dialog box will appear asking you where you want the files to be copied to. Copy them to the correct audio file folder. 8) When you are done copying all the files from the drives you no longer wish to use to the correct drive, quit Pro Tools and remove the attached drives. Then re-open the session without the drives connected to confirm that you have performed the procedure correctly. If so, you should get no relinking dialog box when you open the session. If you do the above correctly, you will save hours of time. Best of luck!
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate |
Relinking Problems "targets of an incomplete render...' | DAEerror | macOS | 2 | 06-17-2019 08:39 PM |
Help relinking audio | Tom Case | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-15-2010 08:47 PM |
Having problems relinking audio files | riffmachine | Pro Tools M-Powered (Win) | 1 | 01-20-2009 03:19 PM |
7.4 still showing problems when relinking | Frank Kruse | Post - Surround - Video | 0 | 12-17-2007 09:58 AM |
PT and relinking problems | Loudigi | Pro Tools TDM Systems (Mac) | 5 | 09-27-2005 08:21 AM |
