Old 06-27-2014, 11:34 AM
Ryan Kelly Ryan Kelly is offline
Default Any help with a recurring HDX crash?
Hey all,
I have a session that's been constantly crashing. Sometimes I can work on it for a few minutes and then it'll crash on opening a plugin (UA Shadow Hills graphics didn't load once before a crash but then after the reboot it was fine and it crashed when I stopped playback). Sometimes the session will crash PT while loading the Misc Windows. I've so far reinstalled PT, uninstalled and reinstalled UA (which made the biggest improvement but hasn't fixed it), deleted prefs (prior to and post reinstall), repaired permissions, built a new session and imported session data and am pretty much at a loss here. Here's the crashlog and would appreciate any thoughts.
Running 10.3.8 on a 2009 Mac Pro with HDX1 and OSX 10.8.5 Other sessions are running fine and I'm not using any plugins in this one that I don't have in other sessions.
Thanks!
Old 06-27-2014, 02:53 PM
Default Re: Any help with a recurring HDX crash?
Try making a fresh session & import session data from your current session.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 06-27-2014, 03:28 PM
Thanks but I've actually tried that with two separate ones. Importing without plugins seems to be stable for a while but importing any plugins and the crashes start happening though not seemingly triggered by a specific one.
Old 06-27-2014, 04:06 PM
Mike496's Avatar
Mike496 Mike496 is offline
Are all of your plugins up to date? Are you running a co install of 10 and 11?
Old 06-27-2014, 09:32 PM
As far as I know everything is up to date, I had worked on this session a couple of weeks ago with the same system (other than using an Apollo instead of my new UAD Octo) but other sessions from the period/with the same plugins aren't having the issue.
Just running 10, don't have 11 installed
Old 06-28-2014, 01:25 PM
Seems like it's an issue with Auto Tune! Not sure why it's giving me a problem in this one and not the others but leaving those inactive has let me have the session open for a half hour which is lovely!
2 Recurring problems with Protools 8 LE andy_m 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-31-2012 10:21 AM
pt 10 audio recurring issues!!!! drumancien macOS 3 09-28-2012 03:16 AM
Recurring LE7 problems AntManBee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-18-2009 08:05 AM
Recurring problem with PT (CPU Overload!?) Please help! kalou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-17-2007 06:57 AM
Help!? Recurring error. I've tried everything. Pootkao 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-17-2007 05:05 AM
