Old 11-06-2001, 11:06 AM
tonyharp tonyharp is offline
Default Using Antares Auto tune
Hello folks,
I am doing a mixdown of a jazz session with horns. Unfortunately the horn players weren't the best at listening across to each other and there a number of tuning problems within the section. I am wanting to use Antares Auto tune on them.
I was hoping someone could steer me in the right direction in using this plug-in. I am hoping to use the plug-in effectively without a noticeable sweep in pitch. Should I use the chromatic/ no scale method or the Key/chromatic method? Any advice I could get on proper settings and such would be greatly appreciated.
Thanks in advance,
Tony [img]images/icons/cool.gif[/img]
If the misery of the poor be caused not by the laws of nature, but by our institutions, great is our sin.
--Charles Darwin
Old 11-06-2001, 01:44 PM
Mr_Seven Mr_Seven is offline
Default Re: Using Antares Auto tune
It's best to manualy set autotune to fix tuning. The auto mode is quick and dirty.
Darren Valen
Cyberdream Studios
Old 11-07-2001, 12:01 AM
executivos executivos is offline
it all depends on how bad it is. I used to use only the automatic tune, because it was easy and it worked ok. Then I figured out the graphical mode and it's much better, but if the notes aren't held atleast a bit, it's hard to do. It usually sounds better that way. I've always set the proper key it works well for me.
Antares Auto-Tune Oblivion777 AAX Plug-ins 2 04-09-2013 02:49 PM
antares auto tune Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2005 03:42 PM
antares auto tune 4 STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-23-2004 10:33 AM
antares auto tune juice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-26-2004 03:10 PM
antares auto-tune need help vince v 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-03-2000 07:01 PM
