Old 10-15-2013, 06:41 AM
markuse markuse is offline
Default The dark side of WRITE TO SELECTION
I know this has been discussed before here an there.
Still, I wonder how you deal with this particular behavior of PT that is:
PT will write automation of the parameters changed in PREVIEW to the whole length of the session when:
1. you press play before selecting a time range
or
2. you don't select a time range at all
..and then press WRITE TO SELECTION.
This "automation pass" will then be undoable.
I use PREVIEW and WRITE TO SELECTION the whole day as it is really handy and probably the quickest way to automate only certain parameters to a selection.
The same time, the mentioned behavior is THE MOST DANGEROUS thing I can think of in PT and can absolutely be a show stopper.
At least in a Post Production Editing / Mixing scenario I would say 99% of the automation written is clip or scene based. I'd really be happy to select the whole timeline if I wanted to write automation all the way through.
Instead it happens accidentally if you don't pay attention like a freak.
Some time later you notice, that your low cut or aux send has been written all the way through and you ruined the automation of 499 of the 500 clips of that track. So you dig around in the last 50 session file backups to find the version just before it happened, import that into the up to date session and replace the blowed up clips.
But that only works for the tracks where you actually notice that the automation has been overwritten... I just can't check the automation of 200 tracks every evening.
I haven't suppressed the warnings but if you hit WRITE TO SELECTION 300 times a day, sooner or later you just read over '..has been written to the whole length of the session'.
So I wonder if there is any use of that feature that makes up for the incredible danger it comes with.
Couldn't there at least be an option in the prefs that would make warnings show up ONLY when writing automation to the whole length of the session? This way you would at least notice immediately that you just overwrote everything..
Best,
Markus
Old 10-15-2013, 06:59 AM
reichman's Avatar
reichman reichman is online now
Default Re: The dark side of WRITE TO SELECTION
There's an Ideascale vote to change this, can't find it at the moment. Brent, Frank Kruse? Where is it?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-15-2013, 07:12 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Yeah, you must be really careful with that one. Drives me crazy for years....
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 10-15-2013, 07:55 AM
found it
http://protools.ideascale.com/a/dtd/...ack/95623-3779
Old 10-15-2013, 11:37 AM
Henchman Henchman is offline
This is why I keep the "write to" warnings turned on. I always know if something has accidentally been written or not. If that happens, I simply undo.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 10-15-2013, 01:55 PM
Yes, I also leave the warnings turned on. But both warnings look pretty similar on first sight and you have to really pay attention wether it reads '..entire length of the selection' or '..entire length of the session' . Doing that 300 times a day.. that's just such a pain and after all, it still happens at the 301st time you hit the button. At least that's my experience.
Wondering if you're always able to undo the WRITE TO command ?
I'm on PT HD 10.3.7 and most of the time it's 'undoable'. Not always though but I haven't ever figured out the logic behind..
Old 10-15-2013, 04:58 PM
emilano emilano is offline
Yes, this is an awful feature and it always amazes me how long its lasted without being addressed...
Old 10-15-2013, 05:57 PM
Yes, AFAIK, it's undoable.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 10-16-2013, 03:11 AM
Indeed one of the most terrible things in PT.
I wish some smart person (Justin from Maggot?) could program a "don't allow write to selection without a selection"-helper app.
I'm willing to pay for such an app instead of waiting for a fix and wiping my automation every now and then.
The warning screens become completely pointless when they warn you even when you write to a selection. It's like having someone in the house who comes screaming "FIRE!!!" every 10 minutes. In case of a real fire no one will escape.
Frank.
Old 10-16-2013, 04:21 AM
paulo m's Avatar
paulo m paulo m is offline
I never came across this as I never use that function. However I find it more easy to write automation to a specific selection in time by clicking on Write to All Enabled. It just takes a snapshot of all parameters of that section.
I use Write to End a lot too.
Hope AVID fixes your request soon.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
HTML code is On
HELP! I may be forced to the "Dark Side" Tim R. Post - Surround - Video 9 06-01-2007 09:19 AM
Help me! I'm slipping over to the dark side.... JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-23-2005 10:19 PM
I've come over from The Dark Side! Jon Dickinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 12-11-2004 06:24 AM
OT: Dark Side SACD? ReniuR Tips & Tricks 4 01-02-2004 12:24 AM
Sould I go to the Dark Side? P. North East 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-13-2002 12:58 AM
