Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 12-12-2018, 02:33 PM
soundartsonline soundartsonline is offline
Default Advise of sorts if Protools 11 tells you you're out of resources
Not that this is a solution to an issue that could be underlying (or a result of Protools needing time to process each task), but just wanted to share how I deal with these error messages so that I don't have to close the file I'm working on down.
First, let me say that it seems that Protools does NOT like it if you try to do too many things at once. I'm learning to just give it a second between each task so Protools can get caught up.
Here's my work around the running out or resources error message:
1) Click Set up/ Select Playback Engine
2) Then change the buffer size
Doing the buffer size change seems to reset the program, eliminating the need to close down and re-open the program.
Hope that helps anyone else encountering this issue. It took a little while for me to find that solution, but it works every time.
Lisa
Old 12-12-2018, 02:38 PM
Southsidemusic's Avatar
Default Re: Advise of sorts if Protools 11 tells you you're out of resources
Yes we have read and posted this info in many threads here on the forum since PT went 64bit.
Not to sound harsh but the search of the topic is a good idea before starting new threads with topics that have been discussed many times.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-13-2018, 07:47 AM
Please reply with link to best answer to this issue if other than the one I posted. After that I will delete the post so to avoid redundancy if you like. Was just trying to be helpful. I took time out of my work to post this. Just send me a private message instead if you have an issue with a post instead of here.
Old 12-15-2018, 04:09 PM
Having more issues now with the same error message. What's the best thread on this one please.
Thank you!
All sorts of problems... Kyle Zielinski Pro Tools M-Powered (Win) 5 06-28-2006 06:31 PM
wah!!! I want my mommy - pt tells me too slow!!!! neomodo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2005 03:10 PM
Digi packed with all sorts of plugins now??? Miike Lee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2003 03:12 PM
The past tells a tale..... PMoshay Pro Tools TDM Systems (Mac) 11 10-25-2003 02:31 AM
A survey of sorts Da Cryptic One 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-18-2000 02:58 PM
