Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
  #31
Old 11-21-2018, 10:06 AM
Default Re: internal sata drive doesn´t show up after restart
Originally Posted by tonwurm View Post
Darryl ... thanks again for your help !
the tape trick was the solution, now the drive works as it should
Great you are set, this is mostly an annoying stupidity the SATA standard inflicts on users, initially seen with large/enterprise drives intended more for servers being used in older Macs and PCs... the drive vendors including Western Digital deliberately delayed implementing that pin change in more consumer focused drives for some time... but eventually it happened with the assumption that most consumer computers are now compatible. The Mac Pro cheese graters are not....
Should have spotted this straight away but got myself confused with mention of two different operating systems that was not relevant.
  #32
Old 11-21-2018, 10:46 AM
tonwurm's Avatar
tonwurm tonwurm is offline
anyway ... you could help me ;-)
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Better to record to a FireWire drive? or 2nd Internal SATA HDD? conrad787 macOS 13 06-21-2012 08:52 AM
ProTools Boot drive migration to a new internal SATA drive audiowave Pro Tools TDM Systems (Mac) 1 05-03-2011 03:45 PM
PTLE w/ Mac Pro - Internal SATA drive order? salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-07-2008 05:57 AM
Another Firewire Drive or Internal SATA II Drive??? fenderguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-14-2007 01:44 PM
External Drive writing to Internal SATA Drive Teen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2007 07:29 AM
