Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 06-18-2018, 10:59 AM
Warpigon Warpigon is offline
Default On M-audio fast track pro "insert" channels
On M-audio fast track pro "insert" channels only work for "mic / nstr" channels or for the whole output signal?
Old 06-18-2018, 07:24 PM
Default Re: On M-audio fast track pro "insert" channels
Inserts are for the input. They are before the A>D conversion. What is the issue?
Old 06-19-2018, 06:27 AM
albee1952 if I connect the compressor via "STEREO JACK + 2 MONO JACK", what will happen in the end?
Old 06-19-2018, 08:21 AM
Whatever input you have should go thru the compressor
Old 06-19-2018, 09:18 AM
The fact is that when I connect the compressor, it only receives a signal from the "mic / Instr" inputs, but not from the PC.
And I assumed that with the insert channel only works with "mic \ instr".
Old 06-19-2018, 09:20 AM
Sorry, I do not speak English well ... and therefore understand you in not full measure
Old 06-20-2018, 01:03 PM
This is correct. The insert jacks are NOT for inserting hardware onto an existing track in Pro Tools. If that is what you want, let me try to talk you out of that for the following reasons:
#1-unless you have some very high-end hardware, using a plugin will meet or beat any inexpensive hardware(Alesis, Behringer, DBX......)
#2-to use hardware inserts in Pro Tools, you need an interface with at LEAST 4 inputs and 4 outputs(2 outputs will always be dedicated to your monitors) as hardware routing can only be done with matched IO(IOW, output #3 with input #3. output #4 with input #4)
#3-using hardware inserts requires delay compensation, which you must calculate and set manually.
#4-using hardware inserts is not likely to make better recordings. Having a lot of skill and experience makes better recordings
If you want to insert an EQ or compressor WHILE recording, that's fine, but be careful with a few things:
#1-don't use too much compression on the way in. You can always add more later(love those plugins) but its pretty impossible to get rid of too much
#2-if you use an EQ on the way in, will you be able to remember/match the settings weeks or months later when you decide to re-sing some phrase that's bugging you
Old 06-21-2018, 08:24 AM
Many thanks for the detailed answer!))
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" EdgarRothermich Pro Tools 12 2 10-04-2017 02:18 PM
M-audio fast track pro - "hardware not connected" kneadingcat FireWire & USB Audio Interfaces (Win) 3 11-17-2014 08:31 PM
"Unable to locate M-AUDIO Hardware" - Fast Track, PT8.0.5, Win 7 JimGriffith Pro Tools M-Powered (Win) 6 10-23-2014 07:35 AM
Fast Track C600 Smells "electric" hollow FireWire & USB Audio Interfaces (Win) 8 12-04-2013 12:37 AM
