Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 03-21-2016, 08:07 AM
emilia.macionczyk emilia.macionczyk is offline
Default Can't create new project
I'm new here. I registered yesterday on Avid and I download Pro Tools First.
I have a problem. I can't create new project. On my dashboard I can see "0/0 projects". When I click create button, I get a note "The maximum number of projects has been reached for this account". I should have possibility to create 3 projects, but I don't have. What can I do?
Old 03-21-2016, 12:03 PM
Defier Defier is offline
Default Re: Can't create new project
Hello there,
I had the same issue at first.
It sounds like you are not connecting to your Avid Account that you created before downloading Pro Tools First.
Remove Pro Tools First and reinstall it and make sure that your ILOK account is setup to activate Pro Tools First.
Once connected, you will be able to create projects in your Dashboard.
Good luck, and more thing... make usre you install ASIO4ALL before installing Pro Tools First... removes issues you might have otherwise.
Thx.
Old 03-21-2016, 02:38 PM
Thanks for your answer, Defier.
I have already done what you said... and still the same.
I removed PTF, installed ASIO4ALL, checked iLOK again and installed PTF again.
My dashboard still says "0/0 projects".
Any other ideas?
Old 03-21-2016, 07:00 PM
Make sure Pro Tools First is installed on your main Windows hard drive. It has to be on the same drive.
I can't think of anything else except that your "Avid Application Manager", which is installed on your PC as well, has to recognized your Pro Tools First installation and license.
Good luck mate. Let us know.
Old 04-07-2016, 02:47 PM
hobomadams hobomadams is offline
Did you find a solution? I'm having the same issue.
Old 04-07-2016, 02:57 PM
DigiTechSupt's Avatar
Hi, Please try Opening Pro Tools First, then log out of your account, then close pro tools first, then open it again and log in to your account. Let us know if the same error occurs.
Best regards,
CD
Avid Audio Tech Support
Support FAQ
Old 04-07-2016, 03:15 PM
Best regards,
CD
Thanks for the response. I tried this and unfortunately the same problem persists. Any other ideas?
Old 05-27-2016, 04:13 AM
bbirney bbirney is offline
Hi. I'm having the same problem. Downloaded Pro Tools First on a fresh install of Windows 10 Pro 64-bit. First installed iLok License Manager and confirmed my Pro Tools First license appears there. Launched Pro Tools First; I have 0/0 projects. See attached screenshots.
My Avid username is '[email protected]', and Pro Tools First accepted my password without complaint.
Why can't I create any projects?
Old 06-06-2016, 10:43 AM
We reset your account, can you please try again?
Best regards,
CD
Support FAQ
Old 08-01-2016, 09:57 PM
eddieandrews eddieandrews is offline
I am having the same problem on my MacBook Pro. I signed up, installed the file, and got the same problem. I cannot create a new project because it says I've reached the maximum, and there are no other files to open. Please HELP!
Also, when anyone gets a working solution, please email / DM us. Thanks.
PS: Avid, I write apps for a living in my "day job" so would be happy to help you fix this if extra coding is needed.
Create New Project - There was an error posting the project. descendant Pro Tools | Intro Discussion 13 04-24-2016 06:35 PM
Can't create a project jazzpalle Pro Tools | Intro Discussion 5 08-12-2015 02:48 AM
New Project's saving to existing Project's??? larsongs Pro Tools 10 9 04-13-2015 02:29 PM
Pro Tools 8 M-Powered Wont Load/Create Project GreenSky14 macOS 1 01-27-2014 03:40 AM
How can I create a Project template Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-10-2006 12:44 AM
