Old 04-29-2002, 05:52 AM
tomcat tomcat is offline
Default simple network question
does g4 native gigabit ethernet need special cable, or will the existing 10/100 cat 5 cable stuff work? How long a run can i have without needing a hub or repeater or something? I am setting up a few rooms with about 10 computers, and I would like to just use the built in ethernet, not some fancy av san, as i will be in brazil. simple is way better in this case.
tom
www.tompaul.com
Old 04-29-2002, 05:23 PM
digz digz is offline
Default Re: simple network question
The typical Cat5 cables are fine. You can do very long runs with these. Id say 100-200ft is the longest I have personally needed to use and has worked fine. You will definitely need a hub if you want to connect more than 2 computers together though. I think the ones from Asante are reasonably priced and work good. The hub is also needed for DSL splitting for all your workstations. I hope this helps you out, Dan.
HTML code is On
Simple question from a simple mind. Terry Wetzel Pro Tools 9 2 11-22-2011 11:00 AM
Simple Question, please someone give me a simple answer! lukaiow Pro Tools HDX & HD Native Systems (Mac) 1 04-19-2011 11:00 AM
Simple question about 8.0.3 that needs a simple answer FS1 Pro Tools M-Powered (Win) 0 12-23-2009 06:37 AM
Simple Question 4 Simple Answer.. tec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-11-2006 05:45 PM
Simple Network Mac to Mac? SteveGarman Pro Tools TDM Systems (Mac) 4 12-11-2004 10:36 AM
