Old 08-27-2009, 10:59 AM
rucontent rucontent is offline
Question midi configuration possibility?
Hello Group,
ahemm first time here...is this thing on (tap tap)
Well i have worked with other programs that have something called key bindings, also midi learning to control many things. I am sure this is not news to anyone here. However i have this griffin powermate usb midi device that i thought it would be really cool to b able to scroll the eidt window horizontally with. Can i? Can you show me the road? Where to turn? Where to look? I tried STFM (search version of RTFM). Thanks if you know.
Old 08-27-2009, 12:25 PM
Default Re: midi configuration possibility? modified
Originally Posted by rucontent View Post
Hello Group,
I just found the answer on the net and i believe the answer is no. But even then if i had a digi002 with control surface or command 8 would i be able to control HORIZONTAL SCROLL of EDIT VIEW?
Old 08-27-2009, 04:34 PM
You will be lucky. Modifier and mouse scroll wheel.
filosofem
MIDI Setup/configuration lecherous MIDI 5 08-18-2007 08:11 PM
midi/oms/001/mac configuration? gino123 MIDI 1 05-04-2001 09:27 PM
Is this a possibility (vst4) x cabs Tips & Tricks 4 05-02-2001 09:08 AM
MIDI-Configuration giotom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-23-2000 04:10 PM
Midi Configuration Brahmb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-09-2000 11:50 PM
