Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 11-26-2020, 05:54 PM
Chris August Chris August is offline
Default Pro Tools Carbon Laptop Fan Noise
Just got my new Pro Tools Carbon interface and this thing is incredible. Only problem I'm having is once I open a session I'm noticing my laptop fan running all the time at a higher level than usual. Even when the session is blank with nothing in it. I'm wondering if it has anything to do with the AVB setup. I've searched around and haven't seen anyone else saying they are having the same problem so I figured I'd post here and see if anyone has heard of or experienced this.
Also, before my Carbon I had a UA Apollo X8 and was using the same version of PT and everything was fine. The fans only started running more once I got this new interface.
Thanks!
Chris
Old 11-26-2020, 08:31 PM
LukeHoward LukeHoward is offline
Default Re: Pro Tools Carbon Laptop Fan Noise
Thanks!
Chris
What does Activity Monitor say? I don't know anything about the Carbon but, I would look at both Pro Tools and the coreaudiod processes, see if they're chewing up a lot of CPU.
Old 11-26-2020, 09:00 PM
Hey! The top usage is "kernel_task" and the next one is "coreaudiod (Not Responding" and that one is in red. I've restarted a couple times and it keeps showing up like that. Could possibly be an Apple call I should make. It just wasn't doing that until I installed the Carbon interface. It uses the Audio/Midi setup in a way I've never seen before.
Old 11-26-2020, 09:30 PM
LDS LDS is offline
Perhaps give the SMC a reset on your laptop - https://support.apple.com/en-au/HT201295
littledevilstudios.com.au
Pro Tools Ultimate 2020.5. OSX 10.14.6. HDX1. DAD DX-32R. DADman 5.3.4.2. Mac Pro 2013. 10 Core 3.0gHz. 64Gb. 4x mSata SSD Drives + 4x HDD. AJA XT IO. Sync HD. Dobly Production Suite 3.4.
Old 11-26-2020, 10:49 PM
How about looking in macOS Activity Monitor (not the Pro Tools meters) and seeing if the CPUs are busy.
Old 11-27-2020, 07:06 AM
K Roche's Avatar
K Roche K Roche is offline
Only having watched a bunch of video's , (Have no clue why it would make a difference on triggering the fan) BUT as far as Audio midi,,,,it seems I remember one video review or webinar, mentioning there should be two Carbon devices showing up in the input device section of audio midi .
One for core audio for use with third party applications (like playing back youtube)
And one dedicated exclusively for PT.
Ah yes just found a reference .
From Sound On Sound article :
"Carbon actually shows up as two devices in Audio MIDI Setup and in System Preferences. This is no accident: one of the two devices is available only to Pro Tools, while the other allows Mac OS itself and any Core Audio applications to access Carbon.Nov 12, 2020"
Be really interested to see if and how you resolve this,,, as I have a Carbon and new iMac coming
System :
Avid Carbon interface , PT Ultimate 2020.12 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 11-27-2020, 09:53 AM
Update: So far I've tried everything I've found on the internet and still haven't solved it. My guess is "coreaudiod (not responding)" is the issue. I've seen from searches this has been an issue with Pro Tools in the past.
I submitted a case to Avid and I'll write back here once I hear from them.
Thanks!
Chris
Old 11-27-2020, 03:42 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Tried removing then re-Installing the driver?
Sounds like the new dual - Hybrid Engine is Core-Audio-Like but not native to macOS.
t
(Help us Help You)<<<click here
Old 11-28-2020, 06:35 AM
K Roche's Avatar
t
It's my understanding there is no separate driver download (is that not correct ?)
System :
Enjoy the Journey
.... Kev...
Old 11-28-2020, 11:22 AM
DetroitT's Avatar
Too new for most to know.
When opening install of Pro Tools
A driver installer (if one) would be in a separate folder there.
?install read me document?
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 04:14 PM
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 07:38 AM
Static Noise with Pro Tools LE and laptop jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2007 11:43 PM
