Old 10-25-2014, 03:26 AM
chocobo chocobo is offline
Default Re: Pro Tools "Ctrl" button not working
Sorry I should have stated that there are bunch of other Ctrl + whatever key combos that are not working, like Ctrl + N, Ctrl + O, Ctrl + =, Ctrl + W, Ctrl + I etc.
Shift key does work as intended in the ways you've suggested.
In addition to Ctrl + Shift not working, Ctrl + Alt also doesn't work, e.g. Ctrl + Alt + F.
Ctrl + Alt + P was registered as Alt + P (Event Operations Window)
and Shift + Alt keys work, e.g. Alt + Shift + D (Duplicate Tracks)
"A" key works on its own (Trimming the head of the region) and works when pressed with Ctrl (Select All), also the number keys worked on their own (different zoom levels) and work with Ctrl (cycle between tools), so it's just strange for it to not be registered with other keys.
I tried using any combinations of the Left and Right modifier keys too, and they act the same way.
Old 10-25-2014, 03:25 PM
Shan's Avatar
Shan Shan is offline
What language do you have Windows 8.1 set at? What language do you have Pro tools set at(Setup > Preference... > Display > Language)? I would give these a shot at the default English setting. If the Ctrl modifier works, then we'll have this narrowed down more.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-25-2014, 07:10 PM
I downloaded and installed the Windows US en pack, and all of the shortcut worked!
So here's what I tried:
Windows locale in Chinese (Taiwan): PT in English and in Chinese both didn't work
Windows locale in English: PT in English and in Chinese both worked
And I just noticed that in the past week the locale subject came up in the Chinese PT community too. People found that just by changing the Control Panel > Region > Format into English, everything worked (worked for me too), so the Windows UI could still be Chinese except date and time format.
One thing I noticed during the PT installation was that the starting splash screen text ("Install Pro Tools", "Browse Pro Tools Documentation", etc.) was garbled. The installation proceeded without any problems though.
At least now we have a work around.
Old 10-25-2014, 08:28 PM
Shan's Avatar
Good to hear you have a working solution now.
Shane
Old 08-30-2020, 07:45 PM
kurokoteresa kurokoteresa is offline
Hi I'm facing the same issue on my ProTools 2020. Did you fix it?
Old 11-27-2020, 05:33 AM
polycorn polycorn is offline
Same here, for no apparent reason CTRL stops working in Pro Tools. Works fine in the rest of the programs, but only rebooting can get PT to listen to my keyboard like it should.
(I don't even bother contacting Avid anymore, first thing they do is look for reasons not to be held responsible for silly annoying bugs like this.)
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] andrew24c macOS 4 07-23-2014 08:21 PM
MBox "launch control panel" button not working again with the latest driver Zarabozo Windows 0 10-26-2012 01:01 AM
"Pro Tools application has stopped working" Sandra report inside... JLiRD808 Windows 2 09-15-2012 09:27 AM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 07:45 AM
"a-z" button stops working on Edit page ilovemyssl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-05-2011 02:30 PM
